Software pc speaker problem
My PC speaker doesn't produce any sound even if i used earphones. However, it does work if i logged onto the administrator account. So, I assume it's the software that has problems...? Is there any way I can fix it without having to format my computer?
  • 74 Answers
Check audio drivers, also check whether or not "windows audio" service is running or not from running services.msc from run dialog box.
Posted on Oct 05, 2009
    Problem Solver:
  • 5 Answers
Create another user with administrator rights, logon to it, and check the sound.
Posted on Sep 29, 2009
Forgot password to log onto computer window7
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • There is a free boot CD called Hirens. This one command prompt only. http://www.hirensbootcd.org/ Just tested this one and works. Just follow the exact steps.
Oct 25, 2012 | HEWLETT-PACKARD HP All-in-One 200-5110 PC...
Hello, I wanted to get a headset to use for online gaming and possibly using programs such as Skype. So I ordered a Logitech ClearChat Premium PC headset from Best Buy. The headset arrived and I proceeded...
Well in this case you need to include also the infomation of your computer like brand , model and Operating system because the problem is not with the headset. Otherwise you can check the settings right through Control Panel - Sound then Playback and Recording configuration
Jan 09, 2011 | Computers & Internet
I did as described. The icon indicates that the speakers are un-muted and when I plug an earphone into the computer, it works fine. The only problem is that the speakers do not work
control panel sounds and audio,volume you can adjust the volume or
advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 06, 2010 | Panasonic Toughbook CF-Y7 PC Notebook
No sound from laptop
The simple damage your laptop and here is you can not move but the socket earphone / headset of your laptop,the opening of outlets are you have seen lock switch is you just poke a gently using the little things like the end of ball pen.good luck and hopefully helped revenue
Dec 12, 2009 | Compaq Presario Notebook
Laptop sound works when using earphones, but speaker suddenly doesn't work without earphones. Have we accidentally pushed a button or something?
When you plug in headphones, very often they get accepted automatically and the sound port changes in the OS accordingly as well. But when you unplug them again, it happens quite often that the OS is not switching it over on its own (even still happens in win 7). Just go into the volume mixer panel/options and change the output back to the port of your speakers.
Aug 02, 2009 | HP Compaq Presario CQ50-211NR Notebook
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
Speaker no sound
In the socket where you plug in the external earphone are bending contacts, which also switch of the speaker when you are using an earphone. Try either putting in the jack and wobbling and twisting it, or tapping the corner with your knuckle.
IN EITHER CASE - BE GENTLE
That will knock of the dirt and the switch will work again
Dec 10, 2008 | HP iPAQ hw6515 Pocket PC
Sound cut
is your ear phone damaged.......or not working....
Oct 21, 2008 | Computers & Internet
I can't get the world poker championship to install on my computer I have windows xp and I don't understand the part about administrator rights account
Im assuming your account doesn't have administrator rights and that your being asked to supply an account with Administrator credentials yes?
if so ask the person who usually installs software on your pc if they could install it for you , otherwise there is no other way unless you can get them to also create you an administrator account , then you would have no problems installing new things on the PC.
When you are logging onto your own account under Windows XP it sounds like you have been supplied with a "Limited Account" meaning you can't do things like install new software to the PC , you can't create new accounts when using a limited account so there is no way you could give your self a "Administrator Account".
The only other solution that i have for you is when you get to the logon screen press alt + ctrl + delete it shold hopefully bring up the administrator account , for the password try it blank or even try admin or administrator or password , but if there is a password on there it's probably because they dont want you to gain that sort of access.
Goodluck !
Thanks
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
