Question about Acer Aspire 5050-3242 Notebook
Acer aspire 3050 operating sysyem not found -media test failure......help !!!! pxe-2.1 (build 082)
IB4G2008
  • 3587 Answers
SOURCE: media test failure
sounds like your hard drive is unhappy..can you boot from recovery disk?
Posted on Mar 13, 2008
  • 5 Answers
SOURCE: acer 5100 help me
OK this is the only way I can get my P.O.S Acer 5100 to work and it does NOT always work...
First off, I downloaded an updated Bios (3.10) it was from the Acer U.K. website and the program to flash it..(caution it may fry your computer) but i was ready to gut this thing and send it back to Acer with a thin layer of horse S*&T on top..there customer service in non existant for this modle....
after flashing the Bios I did a full system recovery from the disks I made when it was new...restarted it and it WORKED....
well it worked for about 2 weeks then the "media cable error" message came up again...if you get the Acer screen hit F2 and you will see your $800 laptop is not detecting the hard drive or dvd rom...hit control alt delete to restart and TAP the right side of the laptop above the hard drive HARD as it boots...if you get really lucky it will work until the next time you move it...seems to be a bad connection near the hard drive...ALSO..my P.O.S has the built in webcam..it will work until i move the cam, it seems to short out the laptop, i get the blue screen of death and it will restart...
if you do get your running I sugest coping all your files, pictures and anything else you value from the hard drive, formate it and SELL IT ON E BAY AS-IS...most bring around $200 for parts and go buy a Dell...
Acer is total ****, mine has been back to Texas for repair 4 times and is not out of warentee..they said I should of bought the extended warrentee, I asked why you people have had it more then I have...you should replace it for free...no responce from Acer...
OH and the left button on the palm rest fell into the laptop after 2 weeks and they refused to repace it for free, said it was user damage
hope this helps you with your POS Acer media connection error
Posted on Aug 25, 2008
nyilasrobert
  • 627 Answers
SOURCE: Acer Aspire 5100-5674 won't boot. Keyboard won't
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Posted on Jul 30, 2009
Testimonial: "thank you"
bob_computer
  • 3153 Answers
SOURCE: aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Posted on Sep 28, 2009
Testimonial: "I found an internal disconectet cabel fixing it solved the bootproblem"
  • 707 Answers
SOURCE: no bootable CD in ATAPI
try downloading from here
http://pci-ven.com/driverdetector/realtek/rtl8139realtek/realtek-rtl8139-x-8130-810x-pci-fast-ethernet-controller-v2-17-051202-.html
good luck
Posted on Nov 08, 2010
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
No bootable CD in ATAPI CD-ROM Intel UNDI, PXE-2.0 (BUILT 082) copyrighr (c) 1997-2000 Intel coperation For realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v.2 13 (0203326) PXE-EGI: media...
good luck
Nov 08, 2010 | Acer Aspire 5100 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Argh girlfriend spilled hair gel on my laptop
thats ethernet card realtek
did you check to see hard drive is securely in tack
saying can't find os
you may need to do a new install let me know
if you took apart you made have caused hard drive to become lose
Jan 17, 2009 | Acer Aspire 3610 Notebook
ACER Aspire 3050: Operating System not found
Some times the hard drives move in their craddles sometimes removing it can fix this when you reseat the connections again,another common fault there is the lock screw for the craddle comes loose and falls out thru vibration and hard use over the years moving from place to place.etc...
Make sure to remove the battery and the power charger for the laptop before starting this process so nothing else happens,I have changed ram before and killed it by forgetting to remove the power and upset the balance of nature inside the laptop and had to start gain with more ram.
Another thing is the hard drive itself could be in need of formatting agian so you may have to remove the drive and take it to another computre to back up your files before your rofmat and start with a fressh windows install agian,at least you get to have a working machine agian....
Good luck and let me know the outcome thanks
Sep 23, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 9410-4933 not booting up
YOU NEED TO REINSTALL OPERATING SYSTEM ... FORMAT THE ACTIVE PARTITION AND REINSTALL
Sep 15, 2008 | Computers & Internet
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5050-3242 Notebook Logo
55 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
