Question about GIMP GNU Image Manipulation Program
How do you change blend mode to burn - GIMP GNU Image Manipulation Program
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GIMP Master
  • 102,366 Answers
In the Layers dialog, click the down-arrow to the right of the line stating "Mode:" and the current blending mode, and select "Burn". If the Layers dialog is not present, press Ctrl-L or select Windows|Dockable Dialogs|Layers from the menu.
Posted on Mar 12, 2010
How to replace the door blend actuator on 2009 lincoln mks
Right side or left ? Electronic Automatic Temperature Control or manual ? Temperature or mode door ?
Temperature Blend Door Actuator - LH Removal and Installation
NOTE: It is not required to install the new LH temperature blend door linkage parts included in the LH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
LH temperature blend door actuator and linkage
  1. Remove the 2 lower steering column opening cover bolts.
  1. Detach the lower steering column opening cover.
  1. Disconnect the in-vehicle temperature sensor aspirator hose and electrical connector.
  1. Position the instrument panel wire harness away from the LH temperature blend door actuator.
  1. Remove the 3 LH temperature blend door actuator screws.
  1. Disconnect the LH temperature blend door actuator electrical connector.
  1. Remove the LH temperature blend door actuator.
  1. Manually operate, and inspect the LH temperature blend door linkage for incorrect placement, binding or damage.
Temperature Blend Door Actuator - RH, Dual-Zone EATC Removal and Installation
NOTE: It is not required to install the new RH temperature blend door linkage parts included in the RH temperature blend door actuator service part kit if only the temperature blend door actuator requires replacement and the linkage parts are not broken or binding.
RH temperature blend door actuator and linkage
  1. Disconnect the glove compartment damper from the glove compartment.
  1. Remove the glove compartment.
  1. Remove the RH lower instrument panel insulator.
  1. Remove the RH lower floor console trim panel.
  1. Remove the 3 RH temperature blend door actuator screws.
  1. Disconnect the RH temperature blend door actuator electrical connector.
  1. Remove the RH temperature blend door actuator.
  1. Manually operate, and inspect the RH temperature blend door linkage for incorrect placement, binding or damage.
  2. Mode Door Actuator - Defrost/Panel/Floor Door
  3. Removal and Installation
    NOTE: The defrost/panel/floor mode door actuator can be accessed from below the driver side of the instrument panel.
    NOTE: It is not required to install the new defrost/panel/floor mode door linkage parts included in the defrost/panel/floor mode door actuator service part kit if only the mode door actuator requires replacement and the linkage parts are not broken or binding.
    Mode door actuator and linkage
    1. Remove the 3 defrost/panel/floor mode door actuator screws.
    1. Disconnect the defrost/panel/floor mode door actuator electrical connector.
    1. Remove the defrost/panel/floor mode door actuator.
    1. Manually operate, and inspect the defrost/panel/floor mode door linkage for incorrect placement or damage.
    Mode door actuator linkage only
    1. Remove the mode door linkage.
      1. Depress the tab and remove the panel door lever.
      1. Remove the floor/defrost door intermediate lever screw and floor/defrost door intermediate lever.
      1. Pull straight outward to remove the floor/defrost door lever.
    1. NOTE: When installing the mode door actuator, make sure that the panel door lever and floor/defrost intermediate lever are correctly aligned with the mode door actuator cam.
      To install, reverse the removal procedure.
Nov 10, 2016 | 2009 Lincoln MKS
2005 pontiac blowing warm air
This could be the blend door on the heater. It is stuck on the wrong position because it is not fully in the heating mode. I certainly hope that no one changed all those parts without checking the mode and blend doors first.
Jan 05, 2016 | 2005 Pontiac Grand Prix
I have a 1992 dodge dynasty and the ac is stuck blowing on the floor it want change I think its the blend door but not sure can you help me
You are close! The mode selector door is the one that has the problem. IT is the same principal as the blend door. Look on the plenum (box that houses the motor and levers for the heater, under the dash) and move the heat and cold select and see which one moves on the plenum, do the same for mode.
Jun 26, 2015 | Dodge Cars & Trucks
Can I use a synthetic blend oil instead of full synthetic oil in my 2006 cadillac SRX
I would check with an oil/lube co on this issue.I personally would not.Sometimes when you change blends a vehicle will start burning oil.
Dec 26, 2013 | 2006 Cadillac SRX
My 1998 Buick park avenue burns gas faster than it usually does. What should I do.
If you use ethanol blended gasoline this is normal. ethanol blended fuel doesn't burn as well as regular unleaded
if you use unleaded non-blended fuel
A good thorough tune up should remedy this.
change spark plugs and wires
air filter
fuel filter
engine and transmission oil and filters should do the trick
Aug 29, 2011 | 1998 Buick Park Avenue
CLICKING NOISE FROM RIGHT DASH ON A 2005 FORD FIVE HUNDRED?
Air/Blend Door Actuator Modual is defective: See info below
Description : Temperature Actuator Attributes : Controls the blend of hot & cold air Make : Ford Brand : Dorman - OE Solutions
Application Notes:
Please select Detailed Applications
Mar 14, 2011 | 2005 Ford Five Hundred
A/c will not switch to heat
control head bad or blend door in heater case under dash is bad. Blend door motor can be electric or vacuum. Do other modes change?
Dec 03, 2010 | 1987 Lincoln Town Car
2 vents blow semi cold aair and the other 2 blow hot air
You have a blend door issue under dash. Also possible blend door actuator motor may have failed. Try moving the mode select dial on control panel back and forth and listen for air sound change under dash at both sets of vents. If do not hear air flow change door is not moving.
Jul 21, 2010 | 2001 Volvo S60
1999 cadillac Deville cold air blowing out passenger side vents
Sounds like a Blend door issue, but could be the controller switch, Test ALL modes of operation to see what works and what does not. That should narrow it down a bit. The Blend doors are flap/ doors that regulate air flow, newer vehicles are plastic - electric assemblies ...prone to failure. Any clicking or thumping noises during switching modes and on-off suggest a bad Blend door. Hope that helps...good luck
Jan 12, 2009 | 1999 Cadillac Seville
Heating system only blows out hot air through the vents
I would look at the air blend doors first, it sound like they are not working or your control in the dash is not working send a signal to them. they work by changing the air from hot to cold or in between.
Avalanche, Sierra And Silverado
  1. Remove the floor air outlet duct extension (1) from the floor duct (2). 0900c152801c9c8a.jpgRemove the floor air outlet duct extension (1) from the floor duct (2)
  2. Disconnect the electrical connection at the blend door actuator (10). 0900c152801c9c8b.jpgBlend door actuator and related components
  3. Remove the blend door actuator mounting screws from the HVAC module.
  4. Remove the blend door actuator as an assembly with the actuator cam. 0900c152801c9c8c.jpgRemove the blend door actuator mounting screws from the HVAC module
To install:
  1. Install the blend door actuator as an assembly with the actuator cam.
    1. Line up the heater/defroster valve lever with the blend door actuator cam slot.
    2. Line up the A/C valve lever with the blend door actuator cam
  2. Install the blend door actuator mounting screw to the HVAC module.
    1. Tighten the blend door actuator mounting screw to 14 inch lbs. (1.6 Nm).
  3. Connect the electrical connection at the blend door actuator (10). 0900c152801c9c8b.jpgBlend door actuator and related components
  4. Install the floor air outlet duct extension (1) to the floor air duct (2).
C/K Series
  1. Disconnect the electrical connector to the mode actuator that is located on the left side of the air distribution case.
  2. Remove the screws.
  3. Remove the adjuster links from the control lever.
  4. Remove the mode actuator.
  5. Adjust the mode actuator by completing the following steps:
    1. Connect the electrical connector to the actuator.
    2. Turn the ignition switch to the RUN position. Allow the self-positioning of the actuator.
    3. Turn the ignition switch to the OFF position.
    4. Remove the actuator from the electrical connection. 0900c152801c9c8d.jpgBlend door actuator-C/K Series
To install:
  1. Install the mode actuator.
  2. Install the screws.
  3. Install the adjuster links to the control lever.
  4. Connect the electrical connector.
  5. Test the circuit operation
Nov 27, 2008 | 2001 Chevrolet Silverado
Open Questions:
See all GIMP GNU Image Manipulation Program Questions
GIMP GNU Image Manipulation Program Logo
Top GIMP Computers & Internet Experts
Rick Moore
Rick Moore
Alun Cox
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a GIMP Computer and Internet Expert? Answer questions, earn points and help others
