Question about Uniden Cordless Phone
I have GE Cordless phone model 27934ge2-a display problem
I have GE Cordless phone model 27934ge2-a. Both phones have issues with the display. I cannot read most of the display, only parts of the numbers and letters appear. Both phones are fully charged. I have disconnected the batteries and reconnected. I have swapped the phones with the bases.
This problem started when I had both phones unplugged for about 4 months.
Any Ideas?
SOURCE: Cordless GE phone issue. 25825GE3-A
i faced a similar problem.try doing this
1) go to handset menu & somewhere u wil find registration
2)it wil ask for pin , try 5555 or 0000
3)it wil display waiting for reg or searching......
4) press the base station button for some 5 seconds until it beeps continuosly & stops....
5) as beep stops press 1 or 2 or 3 or 4 in handset ( no. of hanset handled by base)...try all possibilities ( sometimes takes automatically if u dont press any number)
6) thats it.......
pradee_kb@yahoo.co.in
Posted on Oct 24, 2007
SOURCE: Cordless Handsets don't work
in manual it states that you need to give permission on corded base for handset to link to cordless phone.
Posted on Nov 17, 2007
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
How do I get the blue light and new voice mail cleared from this phone?
Posted on Apr 03, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: GE Cordless 25952EE1 A Cordless wont register in base base flas
After talking with Thomson Inc today your best bet is to get rid of the phone. I found out today this phone has a real problem as I see it. I can use my handset on other bases. So that means anyone with this model handset can access your line. Thomson agreed today that this is possible. All I got was a SORRY!
Posted on Mar 27, 2009
How do i put the ring tone back in the handset
    Does the Phone Power Up?
  1. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  2. Does the Battery Hold a Charge?
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
  4. Listen for a Dial Tone
  5. If the GE cordless phone powers on, and beeps when you press keys, but no dial tone is heard, one of three problems is the likely culprit. The phone's batteries may have an insufficient charge to fully power the phone, a condition that can be corrected by simply placing the phone back in the charger. If the batteries are charged, but no dial tone is heard, it is also possible that another telephone in your home or office is "off hook" or in use; verify that all telephones, fax machines and modems are securely on the hook. If there is still no dial tone, your telephone service may have been disconnected or require service by your local telephone company.
  6. Listen for Static
  7. On some GE cordless phone models, particularly older models, static may be heard if the radio signal between the handset and base unit experiences interference. Common sources of interference include unshielded electronics, appliances, and radio transmitters, as well as high-tension power lines. If your phone offers an option to change channels, try several different channels to see if the static is eliminated. If static continues to exist, or if static can be heard on wired phones sharing the same line, your telephone line may require service.
  8. Verify Your Handset is Registered
  9. Some models of GE cordless phones may display a message on the display screen that the handset needs to be registered. If this message appears, move the handset close to the base unit and press the "Prog/Mute" button near the bottom of the handset. Next, press the "Pager" button on the base unit (your handset may instruct you to perform this step). Finally, press the "Prog/Mute" button on the handset one more time to complete the registration process. Your GE cordless phone should now work correctly.The GE Cordless Phone brand is designed to deliver the conveniences of cordless home service with quality sound and features. There are many models of the GE Cordless Phone. The most current models, including the DECT 6.0, have standard features such as call waiting, caller ID, visual ring indicator, phone number memory and digital answering systems .
  10. Before you use your GE Cordless Phone, ensure that you have all the parts. Your cordless phone package should include the phone base, a handset battery pack, a battery compartment cover, the cordless handset, a wall mount bracket, and a telephone line cord and AC power adaptor. Once you have confirmed that you have all of your parts, insert the handset battery pack into the handset and replace the battery compartment cover. Insert your telephone line cord and the AC power adapter into the phone base. The phone base identifies the telephone line as TEL LINE and the adapter as AC. Plug the phone base into the electrical socket. Place the cordless handset into the base. Allow the phone to charge for at least 16 hours before its first use. Failure to fully charge the battery before its first use will result in poor battery performance.
  11. Once you have fully charged your phone, you can proceed with setting up your phone's features. If your cordless phone includes an answering system, complete this setup process first. Turn on the answering system by pressing the on/off button. The message indicator light will display. The cordless phones are defaulted to English as the selected language. To change your language preference, press the "Skip" button for two seconds. The language will change to Spanish. Next, you will set up your voice time and day stamp. While the answering system is on, press the "Answer" button on your handset for two seconds. The phone will enter the answerer mode. Press the "8" key. This will take you to the time/day setup menu. Use the number keys to set the hour and minutes. Use the volume up and down arrows to set the AM/PM. Press "#" to save. The cordless handset will also require that you give it a name. Press the "Mute" button for two seconds until the handset reads "ENTER NAME." Enter the name of the handset by using the touchtone keypad. Press the "Mute" button to save. Enter the default area code by pressing "Mute" until the phone displays "AREA CODE." Enter your three-digit area code and press the "Mute" button to save.
  12. GE Cordless Phones are designed to be simple and convenient to use. To place or answer a call, press the TALK button. You can pre-dial a number by dialing the number before pressing the TALK button. When you are ready to make the call, press TALK and the phone will dial automatically. To answer a call that is waiting on the other line, press the FLASH button. If you experience call interference or bad reception while on a call, press the CHANNEL button until your line clears
Nov 17, 2009 | Uniden Cordless Phone
I have bought a GE cordless phone model 29670, base unit working fine but cordless unit no sound or display even though battery charged more than 10hrs before first use.
I took the phone to the shop where I purchased, they replaced the battery cordless unit with a new one, now it is OK. All displays are perfect.
Thanks & regards
Balakrishnan.
Oct 13, 2009 | Uniden Cordless Phone
I have a GE model #28021ee2a and can not read the display
Handset needs registration go to the base and hold the cordless near it and hold down the page button till cordless beeps. Hope this helps.
Mar 31, 2009 | Uniden Cordless Phone
Caller id display screen
I can't read my caller Id Screen numbers are disappering
Jul 27, 2008 | GE 25951EE2 Phone
Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
Cordless Phone
You did record a message on the answerer, didn't you? Mine displayed that until I recorded the outgoing message for the answerer. You do not need any service from your phone provider. The answerer in the base unit simply records the caller's message when you don't answer after a set number of rings. The manual tells you how to name the handset, which is a nice feature if you don't wish to use "unit 1, unit 2, etc".
Aug 28, 2007 | GE 28112EE2 Cordless Phone
Whont work, please register in displayed on screen
To solve the register problem.... Put each phone for 20 seconds or so in the main base. I had the same issue, and resolved it this way.
Aug 21, 2007 | GE 25932 Cordless Phone
GE 27831 Cordless - Date Time Issue
should be in the main menu thru the handset setup .unlike cell phones that reset automatically . you must go into setup and do it
Dec 23, 2017 | GE 27831 Cordless Phone
Uniden Cordless Phone Logo
76 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
