Inputs/Outputs or Instruction Manual for Soundlab SP-500
I am trying to fid out which are inputs/outputs on th eback of my inherited SP-500 Can anyone help? Does anyone have an instruction manual Pretty Please!!
raverbaby
  • 59 Answers
SOURCE: Problem with my AX 500
If your amp is less than 5 years old you maybe able to get it fixed for free at http://www.domgen.com check it out we have all our contents covered. This is better than your normal home insurance. Don't matter you could claim 100 times and never loose out. check it out! Also don't 4get to leave me feedback cheers raverbaby01
Posted on Aug 27, 2007
SOURCE: west bend slow cooker model number 84228
Go to this website where you can download a manual from the parts list pages:
http://www.focuselectrics.com/catalog.cfm?dest=dir&linkid=101&linkon=category
Posted on Mar 02, 2008
mrwtech
  • 59 Answers
SOURCE: How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Posted on Dec 17, 2008
  • 4234 Answers
SOURCE: How to connect PA mixer with built-in amp to feedbk dstryr unit?
The feedback unit should be connected between the pre-amp section and the power amp section. As you descrubed the ST-out and P.Amp IN are the ones to use.
Dan
Posted on Jan 22, 2009
  • 250 Answers
SOURCE: I need an instruction manual for 720EF
Supply me an email address and I will give it the access to my BT Digital Vault so that you can down load the copy I scanned in.
Posted on Feb 09, 2009
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    I would like to connect my powered subwoofer (Atlantic Technology model 212 SB) to my Sherwood RX5502 receiver. Unfortunately, the receiver has no subwoofer outputs, only speaker outputs, and the...
    Cables between sources and compatible units rarely need to be physically modified.
    Register and download the manuals for free at retrevo.com
    http://www.retrevo.com/support/Sherwood-RX-5502-Receivers-manual/id/3124dj384/t/2/
    http://www.retrevo.com/support/Atlantic-Technology-212-SB-Subwoofers-manual/id/866dj197/t/2/
    Splicing headphone outputs designed for nominal 8-ohm impedance speakers to a 47K-ohm (typical) RCA load is not a good idea but it might work on the Sherwood because this receiver does not automatically silence your other speakers when the headphone jack is installed.
    There is NO other volume-controlled output to choose. Try it.
    Mar 25, 2011 | Sherwood RX-5502 Receiver
    Hi. I have recently purhased an Acoustic Solutions DVDRW300 DVD Recorder. I have no instruction manual and have no idea how to set it up or work it!! Please help as im totally useless!!
    Hello!
    I am assuming that you want to INPUT your TV/Cable Box to your DVDRW, and have the DVDRW then be able to OUTPUT to the TV.
    Here's what you need to do:
    1. Locate the OUTPUTS of your TV/Cable box at the back of your set. There should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI . Make sure that they are OUTPUTS. It'll probably say TV-out or just out.
    2. Locate the INPUTS of your DVDRW. Similarly, it should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI. Ensure that they are INPUTS.
    3. Match up the outputs to the inputs. Now, I have listed the OUTPUT/INPUTS going from lowest quality to highest quality. So let's say your TV has RCA, S-Video and HDMI outputs, and your DVDRW has only RCA and S-Video. HDMI is ruled out, unless you get a converter (which is pretty pricey). Choose which one, and buy/use the right cables.
    4. Here are the connections for each type of OUT/IN. (TV/Cable >>>>> DVDRW)
    • RCA (Yellow/White/Red) >>>>> RCA (Yellow/White/Red)
    • S-Video + RCA (White/Red) >>>>> S-Video + RCA (White/Red)
    • VGA + RCA (White/Red) >>>>> VGA + RCA (White/Red)
    • DVI + RCA (White/Red) >>>>> DVI+ RCA (White/Red)
    • HDMI >>>>> HDMI
    5. Connecting the DVDRW back to the TV. So now, you can record whatever is playing live on your TV. But you also want to play things from your DVDRW on your TV. Check the OUTPUTS of the DVDRW. It should have either the same jacks as the INPUTS. Check the INPUTS of the TV.
    6. Follow Step 4, and 5. Note that for connections, you are going from the OUT of the DVDRW to one of the INs of the TV. Keep track of what INPUT on the TV you are connecting to.
    Voila! Let's test it, though. Now, turn your TV and DVDRW on. Put in a DVD (a movie perhaps) in your DVDRW. On your TV, switch the channel to the INPUT channel you used. You should see your movie. If not, try another INPUT on your TV.
    If it's fine, then let's try recording a TV show. Switch the channel on your TV to whatever you want to watch, say Cartoon Network. Put in a blank DVD in your player/recorder. Hit record on the player. Let it record about 2-3 minutes, and stop recording.
    Switch the TV back to the INPUT which works, and hit play on the DVDRW. You should see what you recorded.
    Hope this helps!
    Mar 14, 2011 | Televison & Video
    How do i use the high level speaker inputs on this snell QBx sub.
    Most likely, you simply connect the speaker wires to the high level inputs, along with the cable from your amp.
    Given that Snell's are high-end speakers, I would recommend that you contact their tech support for your question. They have a specific email address for technical questions on their Support Page.
    Jan 23, 2010 | Audio Players & Recorders
    Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
    Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
    Aug 11, 2009 | Kenwood KDC-1032 CD Player
    How do I know which converter box to buy?
    here are the specs for the Magnavox TB100MW9
    Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
    Jan 04, 2009 | Televison & Video
    Como conectar un ecualizador Technics SH-E51 a un amplificador Kenwood KA300
    How do I connect my equalizer to my receiver?
    There are two methods of connecting an equalizer, by either using the tape monitor or the main pre-in & output jacks. To connect through the Tape loop, connect the EQ L&R outputs to the Tape-in (play) jacks of the receiver, then take the EQ L&R inputs to the Tape-Out (REC) of the receiver. On the front of the receiver you will need to select the Tape Monitor to access the equalizer.To connect through main pre-out/ pre-in jacks, connect the EQ L&R outputs to the receiver main-in inputs (pre-in), then connect the EQ L&R inputs to the main out (pre-out)
    Oct 05, 2008 | Audio Players & Recorders
    Pc connection
    yes,,,i think it will on run 2 speakers,,, get y cables
    Jul 11, 2008 | Celestion S10 Subwoofer
    DELTA 10/10/LT INPUT/OUTPUT PROBLRM
    Well I guess my problem is a little less important. I have 1-2 3-4 5-? 7-8. I dont know where 6 went. I even checked to see if I could plug a wire into the input and toutch it with my finger to see if I got a vu response, Nothing.
    Jul 06, 2008 | M-Audio Delta 1010LT Sound Sound Card
    Not all Inputs and Outputs are working
    To answer your question I would go to the M-audio desktop icon and double click on it to open it up. Go to monitor and make shure that you bring the levels of each one of the tracks up to 2/3 rd up. Pan each one hard left and hard right and make shure mute is off. Click the top boxes at the bottom of the vu slot and see if that helps. Also you must save it or it will return to the previous settings.
    377 people viewed this question
     Grubhead
    Grubhead
