Question about Toshiba Televison & Video
TVS PICTURE SQUEEZES FROM TOP TO BOTTOM SOMETIMES. THOUGHT IT WAS THE CABLE BUT IT IS NOT
  • 379 Answers
This is normally indicative of an intermittent fault in the field output circuitry.
Unless you have extensive electronics knowledge, and experience of working on standard (CRT) tellys (voltages of up to 15 thousand volts can be found inside the case for the unwary !), this is definitely not a DIY fix - take it to a repair shop.
Posted on Sep 29, 2009
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
TVpicture is too big we can not see top or bottom of picture
Caution: Your Tvs internal voltage is high. Never use the tv in this condition. Many internal components will ge damaged. Repair it as soon as possible. Sometimes vertical height control may misallinged. Anyway get it right soon.
Oct 13, 2010 | Sanyo HT32744 32" TV
Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
May 06, 2010 | Samsung HP-T4254 42 in. Plasma Television
Picture is wiggling. Like waves.
the power supply has variations meaning your supply is not constant, it is not giving the same outputs voltages.
plse check the following
capacitors which have changed values
semi conductors which are leaking.
thanks for trusting fixya.
Mar 25, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Picture horizontal problems
There is a sevice menu but it is something a repair man has to adjust. Even to get to that menu is a matter of procedure. If the picture is not always squeezed down then adjustment is not the problem. If it is intermitant it could be a bad solder connection on the main board.Sometimes a bad vertical ic and leakey capacitors can be the problem..
Bottom line is there is not much you can do to correct the problem. You are going to need a service man
Nov 14, 2008 | RCA F36650 36" TV
Sony Picture Squeezes In On The Sides
check the capasitor near the plyback, the value is: from 160volts to 250 volts
Sep 30, 2008 | Sony KV-24FV12 24" TV
Picture squeezes in and out with a red and green halo around perimeter.
Convergence problems you can get help at PTS 18008447871 or more info at ctechnicians.com
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
