Question about HP Compaq Business NX9110 Notebook
Boot Failure My system would not boot from the cd/dvd rom nor from the hard drive. Literally I cant install the operating sytem. how can I do it without wasting alot of time. From the Bios of the laptop I can see both drives but when it comes to booting from them it is a problem to me kindly help Regards Pablo
  • 23 Answers
Hi Pi, norton ghost is available on 3.5 floppy, try cloning the drive over, and then running a repair install.
CoDoc
Posted on Dec 20, 2007
Attach the Hdd on another pc or laptop with a usb cable and boot that system this problem could be becaus of bad sectors so when you boot the other system with the HDD attached (On which you want to install OS) the syatem will scan the HDD for bad sectors and repair. it.
Posted on Dec 19, 2007
Toshiba satellite L455D-S5976 PXE-E61 media test failure...brand new hard drive What do I do???
You need to boot from an installation CD for the operating system, or the Toshiba restore set. New hard drives are completely blank when you purchase them. The computer is looking for something to boot from and cant find it, so it trys to boot from ethernet. Check your bios set up for boot order and boot devices. You might try disabling boot from network.
Hope this helps
May 04, 2012 | Toshiba Satellite L455D-S5976 Notebook
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
Rhow to install window 7 with a cd rom give me steps
put your Win. 7 DVD in Rom Drive then restart your system -- when your screen shows the options to press F2 then press it then go to boot settings then put your rom drive to 1st boot device and hard drive as 2n boot device -- then press F10 and ENTER. then your system will restarted. then after few seconds your displays shows that "Press any key to boot from CD/DVD...." then press any key to go to setup then follow the steps and install Windows 7 and enjoy it.
Feb 11, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have a HP Pavilion Elite m 9357c that willnot boot up. The screen goes black and says Disk Boot Failure,Insert system Disk and press enter
If it happens that you are prompted by the following error message "DISK BOOT FAILURE INSERT SYSTEM DISK AND PRESS ENTER", "No system disk", it means that the computer did not find the operating system to start (boot).
Causes:
A diskette or CD has remained in the drive
Check out if any diskettes, CD-ROM or DVD-ROM are present in respective drives, remove them and restart your computer
The boot sequence is incorrect BIOS
Enter the BIOS setup of your computer and edit the boot (boot sequence) so that the computer starts primarily on drive C:
A new hard drive was installed
In the case that a new hard drive has been installed, this message is quite normal.
Just insert the correct CD to install the system (usually Windows), then restart, while making sure the CD-ROM is first in the defined in the BIOS setup as first boot sequence.
The hard drive is unplugged
Open the system unit and check that power cable of the hard drive is properly connected.
Corrupted system files
It may happens that some system files needed to boot the computer have been deleted /damaged or that the boot sector of the disc is damaged.
To determine this, start the computer with a system disk or CD-ROM installation of Windows (via the Recovery Console), and once started, type Dir C: to check if the contents of drive C: are accessible. If its ok then the problem comes from missing or damaged files, then you just have to run the command:
fdisk /mbr
sys c:
Note that before any restoration of the boot sector with the command fdisk / mbr, (supposing that there is a virus), it is recommended to use an antivirus running under DOS, such as
f-prot.
http://support.microsoft.com/kb/166454/en-us
http://support.microsoft.com/kb/69013/en-us
Damaged disk
If the hard disk or a partition is damaged:
If it detected in the BIOS setup, there is a chance that it is
not out of service.
If it is, try reinstalling the system through the installation CD, in order to reformat or recover the partition using a utility.
Feb 03, 2011 | HP Media Center m7260n (EG642AA) PC...
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
Windows will not start
Ok ...that message about the PXE is showing up because the computer cant find an operating system on the hard drive for some reason.
Try booting from your Vista DVD ,let setup start then running Start Up repair ....
3. If prompted, press any key to start Windows from the installation disc.
NoteIf your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computers BIOS boot order
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Jan 02, 2009 | Microsoft Windows XP Professional
Cannot boot windows xp
Test the CMOS BATTERY..TO MAKE SURE ITS GOOD IF NOT REPLACE.If it test good leave out for 5-10 minutes replace.motherboard bios should now beat default settings.reenter the bios.move cd to first boot.save changes.if you do not save changes it will not work.place.computer should now boot from disk.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | EliteGroup P4M800-M7 Motherboard
Hi i am tryning to load an operating system onto my brand new hard drive. It keeps coming up with disk boot failure, insert system disk and press enter.. what do ido
Hi, By brand new harddrive, I assume that its fresh and empty.
You need to install the Operating System (OS) in that harddrive.
You can do that my inserting the OS installation CD/ DVD into the drive before you bootup.
If you still get the error, get into the setup mode and change the boot sequence to boot from CD-ROM first.
Hope it helps :)
Sep 21, 2008 | Computers & Internet
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
HP Compaq Business NX9110 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
