Question about HP DeskJet F4180 Inkjet Color All-In-One Printer
I am using refills and my printer won't
I used refills befor and it wprked perfectly. I just refilled the cartridge and since then I am getting a message that my tricolor ink is low. I followed all the steps recommended and even went back to the dealer sbout the refills. He tested the cartridge on his printer and it was fine but it won't work on my printer. Can you help?
  • 159 Answers
Your printer will always think that refills for this cartridge are "empty" because there is no way to reset the ink levels on this type of cartridge. However, if the cartridge is not working you should be able to get a replacement from the refiller you purchased from. There are a few scenarios as to why the cartridge would print in his test printer and not yours. If they printed test pages from a stand alone printer, this does not make sure the electronics are functioning on your cartridge. If they used a test printer (CT-16, shoptester, etc..) it may be that the TSR is out on your cartridge.
Posted on Mar 08, 2010
My problem is that after refilling the tonner it is giving me low quality of xerox and putting contrast at high initially it was working very nicely please give me right suggession
Please use good quality toner and then try it, it will best to use genuine cartridges, rather than refiiled ones, because that will save your money for a long run.
Aug 28, 2012 | Brother DCP-7030 Digital All-in-One Laser...
Lexmark X5690 Use no. 4/5, after refilling, printer will not accept cartridges and won't print.
Try to reseat the cartridges into the printer.
Note that Lexmark does not recommend the use of 3rd party/refilled/remanufactured cartridges. These type of cartridges tend to degrade print quality and cartridge performance.
Jul 06, 2011 | Lexmark X2690 All-In-One InkJet Printer
Lexmark x4650 refilled ink cartridge but printer says it's empty and won't print
Lexmark does not recommend using refilled cartridges. However, if you have successfully used one before, there's a possibility that the refilled cartride got damaged along the process of refilling. Try to insert a different known working cartridge to determine if the other is faulty. Or better yet, try to purchase a new genuine Lexmark cartridge.
Jun 14, 2011 | Lexmark X2500 All-In-One Printer
How to error e5 how to go to service mode
Hum....e5 error.
The truth is...there is no solution for e5 error.
U may see some solutions through web, however, non of them works..
The only way you can get out of e5 error, replace with new cartridge..
or...
prevent it...before you face it!!
How?
Whenever you take out the cartridge from printer, make sure unplug the power code first..
and then take and refill or whatever...
And then when you put it back....do it when power code is unplugged as well.
Personally, I refilled and used CL831 more than 8 times..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 19, 2011 | Canon PIXMA MP150 All-In-One InkJet...
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
Colored refill ink cannot be recognized
It is called e5 error.
For Canon cartridges, after 4~5 refills, the color cartridge cannot be recognized by printer.
In this case...there is no solution so far...just replace with new cartridge.. that's it.
(To avoid e5 error, you need to make sure "plug out" the power, before take out your cartridge for refill. Yes... "plug out" the power cords!!!!
May 06, 2011 | Canon PIXMA iP1300 Printer
Printer continually says put in cartridge even though I have (twice). I have checked over and over that the cartridge is firmly installed. Is there a sensor somewhere which needs cleaning or resetting?
Did you used refilled cartridge?
Sometimes for Canon printer, when u used refilled cartridges, they are not readable.
It's called E5 error.
In this case, you need to replace the cartridge with new one.
Apr 19, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
Printer does not recognize carts
I have refilled my cartridges many, many times. A messy job, but well worth the savings. Never over fill, handle carefully.
The printer will give an error message, but just press cancel, do not order a new cartridge, Your refilled cartridge will work on the lexmark x5470. Good luck.
Oct 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x2550 refilled ink patron
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 28, 2009 | Lexmark X2550 All-In-One Printer
HP DeskJet F4180 Inkjet Color All-In-One Printer Logo
199 people viewed this question
Seeker5211
Seeker5211
