Question about Matsonic MS9317E Motherboard
I have a mb ms8308ep and when i push the power button, don't start but generete 8 beeps. what should i do...? 10x for the assistance
  • 68 Answers
A single beep means that everything is fine
multiple beeps suggest that there is something worng either with the motherboard or with the devices on the motherboard
8 beeps mean that the video card is faulty
change your video card
Posted on Sep 29, 2009
Testimonial: "thanks alot. it was very helpful and very quick answer. thanks again"
When i plug it into the power i hear a beep and i don`t see anything on the screen
just choose your program , white, wheat etc, and push the Start button. Your machine will start kneading in about 20 minutes....
Oct 31, 2012 | Black & Decker Kitchen Appliances - Others
How do i reset the service light on a bhm (voyager) v4 ceiling hoist?
To turn off the service light that is flashing red on your V4 BHM ceiling lift, you have to proceed this way:
1- Power off the lift with the red cord
2- On the hand controller, push on the PROG + RETURN button at the same time and maintaint it
3- Power on the lift
4- Keep pushing on both buttons, and push in order: UP, DOWN, LEFT, RIGHT.
5-The green light will flash and the buzzer will beep 5 times
6- Release all buttons on the hand controller.
7-Push on the UP button many times, till your hear 4 beeps
8-Push the PROG button once.
9-Push on the LEFT button many times, till your hear 3 beeps
10- Push the PROG button once.
11-Power off the lift with the red cord, then back on.
The service light should be off.
May 25, 2011 | Health & Beauty
The camera beeps when we put the card in.
The images you take with your PDC 640 camera are stored on a removable 3.3V SSFDC or SmartMedia 2 MB memory card (also available in 4 MB and 8 MB). Note: You must insert the memory card before you can turn on the camera.
If camera beeps is enabled, the camera beeps if the card is not installed and displays the [ ] message on the Status panel.
To insert the memory card:
1. Make sure the lens cover is closed (the power is off).
2. Open the memory compartment on the side of the camera.
3. Insert the memory card into the slot (gold side of the card facing the front of the camera).
Make sure the card is pushed firmly into the slot. Note: The camera prompts you to format the memory card if it is not formatted. The camera displays the format menu on the LCD viewfinder. Press the button next to Format.
4. Close the memory compartment cover.
If you can, try using a different memory card. Else, your memory card contact terminals inside the camera may have become worn, causing the camera to not recognize the card once it is inserted.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 13, 2011 | Polaroid PhotoMax PDC 640 Digital Camera
My Dell Inspirion 531S desktop won't start back up after power went out at home. Push power button and tries to start up then power button stays amber and tower beeps twice, pause, then repeats. Tried...
if u have another pc at home ,u could try the memory from the dell in it if its compatible.(by dell) reseat the memory,any add in cards,and any video cards,and check all power supply cables to the mb.per the dell site(the 2 beeps are for the memory moduals) though it said to take out the memory and put 1 of them in and boot,if it works fine,then check the other 1.
Sep 03, 2010 | Computers & Internet
I have a Gateway 507gr pc. Pushing the power supply button the fans turn the cpu light turn on and the pc does nothing else.
you'll need a good power source.replace the old one ; remove all conection from hdd ,dvd's etc..make sure you have a speaker on MB.remove all the ram you have and power on the pc ;you must here a long beep folowed by 2 short one's;if you don't hear it your MB or CPU are gone.But if you do hear then put back the ram and remove your video card and power up the pc again , you must hear a long beep folow by 3 short one ; if you don't hear your MB or CPU are gone but if you hear that means the power supply was the problem.
Apr 21, 2010 | Gateway 507GR PC Desktop
Computer does not post. Fans & lights on.
Good day sir, as you describe your problem, as I see it you forgot to replace your Power Supply box. Swap in a new one, see if it runs. Also make sure that your RAM is good.
Oct 13, 2009 | ASUS A8N32-SLI Deluxe Motherboard
MS8308EP MANUAL
http://www.matsonic.com/drivers/view.php?modelID=MS8308EP
Jan 29, 2008 | Matsonic MS9158E+ Motherboard
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
HP desktop wont start up
Hi, depends on the beep sequence, it could either ba a bad memory or a bad video card. By being bad does not necessarily mean defective but could possibly be just loose. Try to open the casing/cover and reseat/push back into place the video card (if it is not built-in) and/or the memory. It is possible that they were jarred loose while in transit. Pls make sure the unit is unplugged before doing this. BTW, being new, you might void your warranty if you open the casing, pls check your warranty card. Hope this works out for you. Please let me know how things turn up. Regards
Apr 12, 2007 | HP Compaq dc5100 PC Desktop
What kind of storage media is supported for DiMAGE 5?
MINOLTA, RM series Type I, 4/8/16/32 MB; Type I, 8/16/32/48/64/80/128/160/192 MB; SanDisk, SDCFB series, Type II, 256/300 MB; 4x USB series, Type I, 8 MB; 8x USB series, Type I, 16/32/48/64/80/128 MB; 10x USB series , Type I, 160 MB; Lexar Media 12x USB series, Type I, 256/320 MB; IBM, Microdrive, Type II, 170/340/512 MB , 1GB
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Matsonic MS9317E Motherboard Logo
333 people viewed this question
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
