Question about Canon PowerShot SD880 IS / Digital IXUS 870 IS Digital Camera
My 880, the camera fell and the lens rim and cover are broke. Camera works fine, but no lens cover, where can I get it repaired in Raleigh, nc
  • 112 Answers
SOURCE: Lens cover won't open when Canon Powershot A520 Camera turned on
I have two Canon Power shots---the A610, and the A630. The lens cover is starting to hang on my 630 when the lens retracts.
If the lens is extended, take your fingertip and try to move the cover a bit to see if it springs open. If not, then the mechanism within the lens needs to be replaced.
Canon makes a great camera, and I would tell you to try to have it fixed if it costs less than 75 dollars. At 75-100 dollars it's a toss-up. More than a 100 dollars---it's your call.
Posted on Mar 26, 2009
t00nz
  • 4738 Answers
SOURCE: Canon PowerShot A720IS Lens Cover Won't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A720 is more complex, but the base procedures are similar:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Mar 28, 2009
t00nz
  • 4738 Answers
SOURCE: broken lens cover **RESUBMITTED to Corrected Camera Type**
It's not really a problem if the lens cover isnt there. The following actually shows how to repair a broken lens cover. But have a feeling yours may be damaged beyond repair, so the next option is removal of the shutters. Be careful that you don't get any of the rubbing alcohol that's spoken of in the following procedures on the lens itself.
Posted on Jun 04, 2009
t00nz
  • 4738 Answers
SOURCE: camera felled to floor lens tries but cannot
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jul 04, 2009
  • 32 Answers
SOURCE: my canon power shot sd630 fell down and the lens
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Posted on Dec 02, 2010
Fuzzy Pictures w/ Nikon D3000
If this is a new camera, it should still be under warranty. I suggest you contact Nikon before doing anything else to determine if the repair would be covered under warranty. Nikon also would be in a position to advise you as to what the problem might be so that in the event that the repair is not covered under warranty, you don't replace the wrong thing.
Feb 07, 2013 | Nikon D3000 Digital Camera
Camcorder repair in Raleigh NC
hi there, you can try this place, call first to see if they can repair your camcorder:
Triangle X-Ray Company
4900 Thornton Road, Suite 117
Raleigh, NC 27616
Phone: 919-876-6156
Fax: 919-872-3986
Jun 26, 2010 | Sony Handycam DCR-SR40 Camcorder
I dropped my Fujifilm finepix camera
The warranty does not cover damage from your dropping of the camera.
Jun 19, 2010 | FUJIFILM FinePix S1800 Digital Camera
My fuji finepix f40d fell on the floor and the AF does not work anymore. I tried looking for a service manual on line, however I could not find it anywhere. Any idea where I can find it, I almost...
A service manual does not cover the lens unit as I found out my self.
What it does cover is general disassembley, parts lists and circuit diagrams.
I got mine from a guy off ebay. His ebay shop is ; flying_dutchmen plaza
Dec 02, 2009 | Fuji FinePix F40fd Digital Camera
Canon 10D works fine after impact but overexposes now.
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI,YOU SAID YOUR CAMERA WAS FALLEN ON THE FACE WITH LENS THEN STARTS OVR EXPOSING PICTURES THEN FIRST CHECK YOUR LENS'S APERTURE IS WORKING FINE OR NOT.ATTACH ANOTHER LENS TO YOUR CAMERA & THEN CHECK THE EXPOSURE THEN IT WILL BE CLEAR WHETHER YOUR CAMERA IS DEFECTIVE OR LENS IS DAMAGED INTERNALLY.REPLY ME ABOUT IT.THANK YOU & ALL THE BEST
Aug 02, 2009 | Canon PowerShot SD1000 Digital Camera
Lens got stuck
It sounds like the lens is now out of adjustment and in order for this to be resolved, you will need to take it to a camera repair shop. I have heard good reports about a company called Ritz Camera. Not much else you can do with it unfortunately.
Jun 09, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Broken lens cover **RESUBMITTED to Corrected Camera Type**
Jun 03, 2009 | Canon PowerShot A630 Digital Camera
My sony digital camera fell and the pictures are distorted
your lens is off by a gear or two, you need to have the lens repaired. see my solution for the W55 if you can DIY.
Jan 27, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Lens problem
The lens mechanism would seem to be damaged in some way.
There is normally no repair solution with this sort of thing because of the fine mechanism involved.
If you have someone you know who can work with fine instruments to take it to pieces.let them try.
I guess as no repair option is available you cant make it worse by trying to find out
Otherwise - new camera
Jan 16, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
Lens error
your lens are stuck! did you drop the camera? you need to get a repair on the lens
Jan 10, 2008 | Nikon COOLPIX L3 Digital Camera
Canon PowerShot SD880 IS / Digital IXUS 870 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
