When I turn on my Lanier 2138, I get an error code of SC 471. WHat can I do or what does it need?
bowdo
  • 78 Answers
SOURCE: LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Posted on Feb 12, 2008
  • 990 Answers
SOURCE: service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
Posted on May 15, 2009
  • 457 Answers
SOURCE: WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS
SC is for "Service Call". The error may be caused by a defect or an irritation of internal sensors.
Ricoh recommends to physically switch off the printer, wait for a few minutes and power on again. (Irritation by change in surrounding temperature)
If you recently replaced any movable parts inside, remove it again and reseat, many parts inside are checked by sensors for proper seating.
If this does not help, you need to call Ricoh customer service.
Posted on Feb 09, 2010
  • 903 Answers
SOURCE: Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Posted on Jul 19, 2010
aviral_srms
  • 1216 Answers
SOURCE: I have a Lanier 116cn
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good
if this not helped it will need to be checked by a technician.
Posted on Mar 06, 2011
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
LANIER 5637 FAULT CODE SC542 UPON POWER UP
You have a Fuser Temperature warm-up error, Hot roller warm-up error.
Verify the heater lamps, thermistor and thermofuse continuity.
Enter in the SP mode, turn OFF the main switch, unplug the machine, wait 10 seconds,
plug in and turn ON the copier.
If you need to reset the fuser,
Enter SP 5-810 (SC code reset) and
select "1". Then simultaneously press the Original Type key and the OK (or
R/#) key. (There is no need to turn the main switch off and on.).
Jan 22, 2011 | Lanier Office Equipment & Supplies
WHAT DOES THE SC 38 MEAN ?? WHAT FAULT DOES THIS SERVICE CODE REFER TO?? I HAVE A LANIER 2138 COLOUR LASER PRINTER, (SAME AS RICOF AP3800 SERIES)
Feb 09, 2010 | Ricoh Aficio 3800CMF Laser Printer
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
Service code 561 error
May 15, 2009 | Lanier Office Equipment & Supplies
The function read out has gone dark on our LANIER 2138 COPIER/PRINTER
did you turn the dial to light the display? if so the back lights are out on the display or the ballest is bad. you need to replace the diaply. have a tech come out.
May 14, 2009 | Lanier Office Equipment & Supplies
Printer stopped in the middle of a job with the reported error SC 555 Power On/Off and if it continues, call a service technician. They won't come becaue the printer is 5 years old.
When the fusing unit is not
running in the Ready condition,
the pressure roller fusing lamp
keeps ON with full power for
100 consecutive seconds.
Replace the fusing unit.
Apr 23, 2009 | Computers & Internet
Oct 27, 2008 | Lanier 1205 Copier
Feb 11, 2008 | Office Equipment & Supplies
Unable to print more than 3 copies of anything
What error if any do you get? Sounds like your printer needs a firmware update.
Carl ( Lanier tech )
Oct 24, 2006 | Lanier 5222/27 Laser Printer
32 people viewed this question
jasbo
jasbo
