Question about Garden
Was told by mechanic that my JX75 mower may have a air bubble in the carb.(mower stalls after moving idle lever back from full choke position). Would like to try to repair myself.Where can I get a copy of the repair manual for this model and does this diagnosis sound like the real problem? Thanks for any help.
  • 855 Answers
Air bubble doesn't sound right. Sounds more like a carb adjustment. You should be able to get a manual from SSBTractor.com
Posted on Sep 29, 2009
Johndeer la140 runs good on full choke but throdle lever does nothing it is not broke the butterfly is moveing in the carb but no gas response runs good on full chock but when i put the choke down ...
WHEN YOU GIVE A CARB CHOKE, IT RESTRICTS AIR FLOW AND GIVING THE ENGINE MORE GAS INSTEAD OF A REQUIRED MIXTURE... USUALLY THIS IS FOR STARTING IN COLD TEMPS. UNTIL THE ENGINE WARMS UP AND YOU RETURN THE CHOKE BACK TO NORMAL. THAT IS ALL THE CHOKE DOES.... IT DOES NOT MAKE THE ENGINE RUN BETTER BECAUSE YOU THINK IT WILL.
Jan 06, 2015 | Garden
What can I do to get my 1975 dodge RV with 360 2 bbi from stalling when put in gear
the other setting for the idle is not done you have the curb idle done but when you drop it into gear it stalls out go to where the choke is and adjust it you'll see a screw there move the throttle lever back and forth so you can see where it is that screw will increase the fuel going in to keep it running raising the rpm's make sure the choke plate is in the proper position to it could be closing all the way blocking the air out which is needed for combustion in the cylinders
Aug 25, 2014 | Cars & Trucks
Crafsman 25cc weedwacker won't stay running
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Apr 19, 2017 | Craftsman 25cc Gas Line Trimmer
Poulan pro honda engine stalls as auto choke lever moves
Hi, when you say you cleaned the carb, did you strip it down and blow all the jets out with compressed air? If so, check that you have fuel flowing into the carb. If all this is ok check the valve clearances. Regards Phil.
Jun 24, 2012 | Poulan Garden
it sounds to me that there s a jet inside the carb that is still plugged
Jun 24, 2012 | Poulan Pro " Pro" Self Propelled Mower
What does the choke look like?
The choke is connected to the back of the carb, it closes off the air supply to produce an overly rich fuel mixture to aid starting, if it has a choke ( not all engines do ) there will be a mechanical arm clearly marked on the side of the carb, lawn mowers will normally have the choke operation on the throttle lever, if there is no choke decak on the throttle lever the engine may well have a reb primer button on the carb, or an automatic choke if not.
May 14, 2012 | Briggs & Stratton Garden
Engine will stall when levers are moved from park position to center unlock position.
You didn't mention if the same thing happens engauging the mower deck. If it does both, start with the carb and choke. also, check out the safety switch on the steering handles for a loose wire or a ground short. This should be fairly easy.
Jul 09, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Hi Experts, I have a McCullough lawn edger/trimmer Mac-Pro I. I am having problems staring the engine. I can't remember whether I have to hold the throttle in whilst pulling the cord? Also,...
Yes, the throttle should be in the full in position. When starting, the choke should also be in the full on position.
If you can't tell if it is in the closed or open position, remove the cover that is over the carb where the air filter is and you should be able to see which way you move the lever for the closed or open position and mark it where you can see it. When starting put the throttle full on and the choke also in the full on position. It should usually start and stop right away. Now move the choke to the full off position keep the throttle in the full on position and it should start in 2 or 3 pulls. If it doesn't do the procedure again. While you have the cover off the carb check the air filter and if it is very dirty replace it or clean it off because a really dirty air filter could make it run rough or not start at all. I will gladly answer any questions. Best regards and good luck.
Dec 28, 2010 | McCulloch Lawn Care: Trimmer Plus...
I have trouble initially starting my MTD Yardbug mower. Once going, the engine runs great, but it seems like when the throttle lever is set to choke, it doesn't actually choke. I usually have to either...
Sounds like your throttle cable is out of adjustment (i.e. when you put the carb in choke position is doesn't actually go into choke).
Aug 24, 2009 | Garden
31cc Ryobi weed eater engine will start, then stall shortly after
you need to adjust the carb ,look for small screws around carb turn out 1/4 to 1/2 turn good luck
May 24, 2009 | Black & Decker 19" Electric Lawnhog...
Garden Logo
252 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
