Question about Frigidaire FGQ332ES Gas Dryer
I've got a fridgedaire gallery gas dryer, approx 8 years old. Takes too long to dry clothes. I've cleaned inside as best I could and the dryer duct. Is seems to get hot some of the time, but not constant
  • 31 Answers
If you use fabric softener. i recommend you slow it down...alot. an appliance guys nightmare is just that. inside fabric softener, is wax. your lint screen may look clean. but run it under hot water. ive come across many a lint screen where the water will simply not go through the screen, even though it appears to be sparkly clean.
Posted on Oct 07, 2009
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
I just bought one gas dryer-MDG17MN. why it takes so long to dry the clothes, it takes almost 2.30hrs to dry 4kg clothes.
remove the front cover and clean out the entire interior unit including the air flow duct workany restrictions in a gas dryer especially will increase dry time considerably
Sep 11, 2011 | Dryers
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
My kenmore elite dryer is only 1 year old and does not seem to get hot and takes long time to dry clothes
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
our dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Dec 12, 2010 | Kenmore Elite HE4 Electric Dryer
I bought the fridgedaire dryer in 2005 and it has to run 3 times for ~40 min each to get the clothes dry. At first I thought it was from the # of turns prior to vent access in my apt (3 elbows and 30 ft...
due to the issue you had in your old home this is what id look for,,,,lint is bilt up in your unit remove the filter and use a dryer brush to clean lint as best you can,,,,,,second remove the vent hose from the back of dryer then with vent OFF try a load to dry if it drys in one setting then you have deturmind the dryer is ok but the vent hose is bad,,finally a bad thermostate or broken heater coil may be the issue and wold needservice,,,try the free stuff first thoe and good luckwww.myabcspace.com/washerwizzards
May 17, 2010 | Dryers
Bosch Nexxt 500 gas dryer takes a long time to dry
if you use fabric softener sheet,there is two small metal chrome stip take a wet rag clean them off,they are locate on the in side of dry drum close to dry grill on inside,those sheet can leave a film on those stip are your sensor for the auto cycle on the dryer
Apr 24, 2010 | Bosch Nexxt 500 Dryer
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
Dryer takes too long to dry clothes. it usually takes two complete cycles to dry . ( dryer is a kenmore approx. 3 years old, but out of warranty
this is an airflow problem. make sure you are using a rigid metal duct behind the machine and not a flexible one. clean out the exhaust duct behind the dryer and in the wall all the way to the  outside. any residue of lint inside these ducts will increase drying time dramatically. basically clean everywhere the air flows.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 16, 2008 | Dryers
Frigidaire FGQ332ES Gas Dryer Logo
187 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
