Question about Boating
What is the pluge gap nad apossible cause of very rough idle 40 h
What is the pluge gap nad apossible cause of very rough iddle 40 hp yamha
  • 86 Answers
.035
Posted on Oct 16, 2009
How you know when you have bad fuel injecter
you would need to do an injector balance test with a scan tool to see how the injector reacts to the test. rough idle my be caused from a number of issues including bad motor mounts, bad gas, incorrect spark plugs, or incorrect spark plug gap, bad idle air control valve, air in cooling sys, etc....
Aug 28, 2014 | 2006 Nissan Maxima
Why does my saturn sound so bad when idles?
if the car is loud/noisy there is a hole in the exhaust system and this will cause a rough idle because of a loss of back pressure and the vales will not open and close properly resulting in the rough idle it also will make the engine run hotter and this will cause your spark plug gaps to increase and the spark will be less than needed to ignite the fuel in the cylinder for proper combustion which will result in poor gas mileage and lack of power is the check engine light on?
Aug 23, 2014 | Saturn SL Cars & Trucks
2001 ALTEZZA ENGINE ROUGH IDDLE
Hey
"Great choice of service Repair and Manuals"Large pictures deals or discounts is there.You buy in less amount so please use it
Dec 09, 2013 | 2001 Toyota Altezza
94 nissan altima won't start and iddle after cleaning IACV valve
An IAC (idle air control) motor is designed to adjust the engine idle RPM speed by opening and closing an air bypass passage inside the throttle body. The cars computer or PCM (powertrain control module) receives information from various sensors and will output signals to adjust the idle air control motor in or out to adjust engine idle speed by controlling engine idle air. An idle air control motor can fail one of two ways, either the motor short circuits and stops working or the motor will develop high resistance and cause the idle air control motor to react slowly, either failure can cause the engine to stall at idle. When a trouble code scan is performed it sometimes won't always detect a failed or weak idle air control motor.
Oct 08, 2012 | Nissan Altima Cars & Trucks
Check engine light even after servicing to correct
you have a misfire, the eng light flashes,avoid driving it , or it can damage the cat converter,i dont know what repair was done, but if you replaced the spark plugs one may be damaged, or incorrect plug gap can cause this concern.
Oct 11, 2009 | Audi A4 Cars & Trucks
2004 caviler exhaust is glowing but cat is not pluged and car has no power and runs rough.2.2 ecotech
Check the egr flow,if it's stuck in the open position it will cause a rough idle and over heated exhaust temptures.EGR= exhaust gas recirculation
Dec 25, 2008 | 2004 Chevrolet Cavalier
Miss firing
could be a wire crossed, or it's out of time. since you used motorcraft plugs, did you set them properly to the correct gap? replacing plugs without gapping them can cause the sluggishness, out of time can cause the mis-fires and rough running.
Nov 27, 2008 | 1994 Ford F150 Styleside Supercab
Boating Logo
32 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
