Question about Fuji FinePix 2800 Zoom Digital Camera
How do I format memory card on finepix 2800 - Fuji FinePix 2800 Zoom Digital Camera
  • 90 Answers
Go to setting and select erase all...this will erase all data on the card
Posted on Sep 29, 2009
  • 4,806 Answers
First of all make sure the write protect lock is off on the left hand side of the memory card, the slide lock should be in the up position.
Press the MENU/OK button on the camera to display the menu. Use < or > buttons to select ERASE. Then use the up/down buttons to select FORMAT, then press the MENU/OK button.
Press the BACK button to exit the menu.
Please be aware that all data is erased from the card so make sure to back up any file you might want.
Regards.
    Guru:
  • 173 Answers
3 Suggested Answers
markevans
  • 148 Answers
SOURCE: SmartMedia - how to download images without USB cable
get a new cable. or a new card reader. i prefer card readers as i can take my camera around to various events, and if a friend wants an image, he can attach the reader to his computer (if nearby) and get what he wants.
are you sure your computer can directly read smart media cards?
possible it does, but not that common unless its fairly new.
mark
Posted on Dec 22, 2007
peeface
  • 180 Answers
SOURCE: finepix s700 says memory full and wont take more pictures with sd
have you made sure the memory card isnt locked? there is a little switch on the side of the card, try messing with that
Posted on Feb 20, 2009
Sorry it says card error then card not initialized.
If you mean that your camera won't format the card, make sure you're using a card the camera can use. For example, if your camera can only use SD cards, then it won't work with an SDHC card.
Nov 13, 2011 | Fuji FinePix 2800 Zoom Digital Camera
In photo mode the camera viewfinder go's off but the lense does not retract, in viewing photoes mode it works perfectly
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 18, 2011 | Fuji FinePix 2800 Zoom Digital Camera
Camera says "card not initialized" and won't operate...help!
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure.In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
May 20, 2010 | Fuji FinePix 2800 Zoom Digital Camera
I copied pix to laptop using Nikon Transfer. I
Try formatting the memory card in the FujiPix 2800 camera. See if that helps..
Oct 01, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Have a Finepix S602Zoom which on warning display now shows ''Card not initialised''- have bought a new 4GB card- but still have the same problem.. Any ideas - software prob?
This is a common error in the FinePix product range. When you receive a "Card Error" or "Card Not Initialized" message, this indicates that your camera's memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most users will use the "delete all" feature and continue to take pictures but by doing this the file format of the card may become unstable and unusable.
Fuji recommends formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted the images will not be recoverable. So format the current cards and they should be useable again.
Sep 25, 2009 | Fuji FinePix S7000 Digital Camera
FinePix A330 "CARD ERROR"
As long as the card is not an "H" or "M" type card (new configuration, not compatible with your camera, all you need to do is perform a "format" via the setup menu. That will prepare the card for use, however it will erase anything on it.
Aug 26, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Card issues
try formatting your memory card
Apr 10, 2009 | Fuji FinePix 2800 Zoom Digital Camera
Missing Download Disk, Thrown away with Camera wrapping
software for 2800: go to fuji site for download. also, you can remove the memory card and insert into a reader avail for about $8.00. your computer should not need special software to read a memory card from a reader. if your computer has a usb 2 port, use a usb 2 reader to save time. mark
Nov 24, 2007 | Fuji FinePix 2800 Zoom Digital Camera
mark
Nov 01, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Memory Card Problem
Does the camera works fine with the previous memory card ?
Sep 03, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fuji FinePix 2800 Zoom Digital Camera Logo
212 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
