I got sound no picture the colored lamps in side work it will get snow when i unhook cable what is it
  • 5,138 Answers
Change input onTV.LIKE cable/air
Posted on Sep 29, 2009
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Why is my picture color distored color?????????
Your color is distorted because your color wheel is probably going bad. Try resetting all the picture values first. Sometimes they need to go back to normal when the lamp is changed. Lamps only provide white light and have no bearing on colors unless they are very dim. Also check your cables. a loose or bad cable can cause this as well. Lastly make sure your new lamp is made by Osram or Philips. knock offs wont work.
Feb 21, 2015 | Mitsubishi WD Televison & Video
Had sound no picture isn't cable box I unhooked
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 05, 2014 | Televison & Video
I have a 43 inch samsung DLP tv 2004 model# HLN4365W, I was getting a black and white picture, so i replaced the color wheel which was broken. It worked fine for a couple of days then there was no picture,...
No picture on a DLP when you can see the lamp is working is ALWAYS the DLP chip. BECAUSE you recently replaced the color wheel, i suspect that the LVDS/data cable to the light engine was not plugged in well and has come loose. I suggest checking and rechecking every cable and plug you can find.
Aug 09, 2012 | Samsung HLN4365W 43" Rear Projection...
The sound on my 95 hitachi bis screen tv works but there is just lines and snow on the screen, there is no color to the screen.
The tuner is bad, try directingthe signal to the Video input, and put the set in Video mode, you will also have a better picture,,use RCA cables from signal box to TV.
Aug 10, 2011 | Hitachi Televison & Video
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Red?Green picture
You may have inadvertantly loosened a cable connection to the DMD or logic board... You might be able to shut it down, unplug the unit and remove the lamp.. With the lamp out take a good flashlight and shine it into the lamp housing area inside the Tv and see if you have any wire obstructions that you could have contacted with the edge of the housing as you were removing or inserting the lamp...
Bill
Dec 18, 2007 | Toshiba 50H72 50" Rear Projection...
Scrambled Picture/Snow Screen, has sound, can play DVDs through colorstream
I had this with a rca once. Can you hear a crackeling noise coming from the flyback transformer? My problem was just the wire was loose
Sep 27, 2007 | Toshiba TP50H50 50" Rear Projection...
Poor digital picture Toshiba ZP38 TV
Hi. Sounds like DRY JOINTS WITHIN DFS MODULE. This is a pcb within a rectangular metal screened box on the left hand side of set when looking from the front. Will need resoldering be carefull very fine print will need decent soldering iron with fine tip & poss magnyfying lamp to aid looking. If your not at all sure take to repair shop. This TV is nice set has one of the best crt pictures you can get.
Sep 05, 2007 | Toshiba 32AF42 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
