Question about Canon PIXMA MP130 All-In-One InkJet Printer
Cartridge jammed error 5100 - Canon PIXMA MP130 All-In-One InkJet Printer
  • 4,041 Answers
Hi You can Try 2 things.
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Error 5100
When the message "Printer error has occurred 5100" is displayed, the behavior of the FINE cartridge holder is interrupted.
Do you see a jammed paper or foreign material? Did you install the FINE cartridge holder properly?
Please see the following for detail.
If the problem persists, contact the service center for repair.
Aug 15, 2013 | Office Equipment & Supplies
My printer just quit working and comes up error5100.
Error 5100 describes a minor physical error. Usually a paper jam or improperly seated ink cartridge. Check the printer for paper jams and re-seat the ink cartridges according to the owners manual and you will be ok.
Dec 05, 2011 | Office Equipment & Supplies
I have an error 5100. What do I do?
Error 5100 is a cartridge jam , you will need to remove the ink cartridges and reinsert them into the printer and make sure nothing is blocking for the cartridges to move better if you can blow a compressed air to it to make sure all small piece of paper that can cause these error will be remove.
Jul 12, 2011 | Canon PIXMA MP470 All-in-One Printer
I am getting an error 5100 message. On the printer it says cartridge jammed thanks
Hello and WelcomeError 5100 means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed
If it is HELPFUL, Please Rate it as Four Thumbs THANKS
Mar 08, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Printer is giving me an error 5100 error code. What does this mean?
Error 5100 points to a "carriage jam" .The carriage is the assembly that contains the printhead and cartridges.
I hope this helps
Mar 08, 2011 | Canon PIXMA MX700 All-In-One InkJet...
I have an error - "cartridge jammed" pop up window advises to re
Please refer to Canon web site for specifics on resolving cartridge replacement and error 5100.
There's even pictures to help.
Apr 11, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon error 5100 cartrige jumped
I think you are seeing "ERROR 5100: Cartridge Jammed", right?. Here is the most likely solution to this issue with your printer. The following procedure comes directly form Canon
ERROR LCD: CARTRIDGE JAMMED
1. Press ON/OFF switch to reset the multifunction device 2. Removing obstructions, foreign objects and paper jams MP750 / MP780 3. Reseat MP750 / MP780 print head 4. The MP780 may require repair
Feb 08, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Error 5100 on MP450
It sounds like the fine cartridge movement is being restricted.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Oct 18, 2009 | Canon Pixma MP450 All-In-One InkJet...
5100 ERROR
As per the manual...
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
Mar 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
183 people viewed this question
old marine
old marine
