White spots on printed job - Office Equipment & Supplies
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
White ink printing with alps MD 5000
To print white, you need to use the spot color option in the printer properties. The object to be printed must be all black. It seems counter to what you might think, but the spot color mode will print the solid black areas as the selected spot color.
Mar 09, 2010 | Alps MD 5000 Thermal Printer
White lines across print
If you lay the print on the exit tray face up and open the cover. Look on the encoder strip, the clear plastic strip behind the carriage, you should see an ink or grease spot right above where the bad spot on the page is. Wipe the encoder strip with Q-tip or wiper with alcohol. Prints should look better.
Jan 08, 2010 | HP OfficeJet Pro k550 Printer
Imagerunner 2270 prints with spots
you can try to clean your scan glass and optics if that does not work you will have to call tech
Feb 09, 2009 | Canon imageRUNNER 2270 Copier
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Ink spotted printing problems
hi friend
ur cardige have been damged u have to do this try to clean ur cardige going in by printer maintaince tools if problem occres then replace the old cardige
Mar 31, 2008 | Brother HL-2040 Laser Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
jasbo
jasbo
