SOURCE: Cover tab broken on Lexmark X3470
Have you recovered the tab? All the tab does is interrupt a sensor beam between 2 points. Either glue it back on (epoxy or super glue, use sparingly on one side then apply and hold down until it sets, about a min. or tape a popsicle stick into the area where the tab rested. First feel around with the stick in the area until the printer responds. then fix it there.
SOURCE: Lexmark X125 keeps saying cover open change cartridge
try to make sure that the clear "ribbon" is situated correctly inside the unit, otherwise it will not communicate correctly with the moving electronics in the cartridge tray
SOURCE: changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
NOTE: The ink
cartridge should be in the up/loading position unless the printer is busy.
1.
Squeeze the tabs on the cartridge lids and lift the
cartridge lids up. The cartridge pops up when the lid is fully lifted.
2.
Remove the cartridges.
3.
Check and make sure that all of the protective tape has
been removed from the contacts on the ink cartridge.
4.
Replace the cartridges.
5.
Snap the lids closed.
6.
Close the printer's front cover.
7.
When prompted on the printer's LCD to choose New or
Old, choose Old.
8.
Press the Select button.
This was from Dell's website.
Thanks.
Ben.
