Question about HP Pavilion dv8000z Notebook
WILL NOT BOOT IN ANY MODE, HDD TEST FAILED, DO NOT HAVE RECOVERY DISCS? TRIED F11 WHEN BOOTING, ASKS TO INSERT RECOVERY DISC#1, WHICH I DON'T HAVE. HUSBANDS EX-PARTNER MAY HAVE MADE BACK UP DISCS BUT DON'T HAVE THEM EITHER. CAN U HELP ME PLZ?
  • 24 Answers
If the HD test failed you may need to replace the hard drive and reload the operating system. If you don't have the disks you will have to purchase a new copy of the OS. If you have the product key you might be able to use someone's copy of Windows and use your own Key.
Posted on Sep 29, 2009
I need to repair XP in my HP xw4600 . F10 at start shows all boot devices but with key F9 only the hard drive is available
You can contact HP Support Help Number to get more information about goods and services. If you need any further assistance, just call at HP helps number +1-888-687-4491 for the best possible solution. The HP help Number is available on our contact us page.
Mar 18, 2018 | HP Computers & Internet
Boot up problem
Dear sir/madam,
Please try these following steps.
1.) First You Need to Check if the HDD is Working Properly Or Not, So First Turn off Your Computer Completely and U Have to Tun it Back On.
Now As Soon as U Turn it On(Before the Compaq Screen Disappears, Keep Tapping the F10 Key Immediately To Go to BIOS.
Now In Your BIOS Go to The Tools Option and Execute the HDD Self test, Both Short and Long
[If the Test Fails Call Compaq Support @ 1-800-HPINVENT For Replacement]
[If The Test Says No IDE Device Found - U Must Try to Reseat the HDD]
[To Reseat the HDD - Turn U R NB Upside down and U Will Find a Comparment That Has the Symbol of Stack of Discs or Cds, Just Unscrew the Compart Ment and Pull the HDD Out, Then Put if Back it And Screw it Back]
Dont Worry - The Steps I Quote Here, Are Compaqs Prescibed Steps and It Will Not Void U R Warranty, If Fact If U Call Technical Support, They Will Advise U to Do the Same thing!!!!
If Both the Tests Pass then The HDD is Fine(90% It Should Not Be the Problm)
2.) Again Turn Your Computer Off and Turn it Back On and Before the Compaq Screen Disappears, Tap the F11 Key Which Bring Up the Built in Recovery Partion Menu.
From then On It is All Menu Driven
Note : Select Destructive Recovery If U Don't Have Any Importat Data in U R HDD
Else Select Non Destructive Recovery
For more information Contact:
www.hp.com/support
Good luck
Thanks
"Don't Forget to rate the solution"
Jun 26, 2008 | Compaq Evo N110 Notebook
Hdd driver for WD 3200BVT-80JJ5TO DATE. 6 OKT 2011. And how it happen was when I was reinstalling windows I deleted the driver for hdd and now I am really in trouble..... Please answer A.S.A.P. Thank
Paul,
The driver for the HDD is actually built into the HDD. Windows 7 contains a driver to communicate with the drive. If you have a backed up copy of your operating system (created by you on DVD's or CD's when you purchased the machine) then you have all you need to do a complete erasing of the hard disk and restoring it to the way it was when you purchased it (all your added data and programs will be lost).
Performing a system restore:
HP Recovery Manager software allows you to repair or restore the computer to its original factory state. HP Recovery Manager works from recovery discs, a recovery flash drive, or from a dedicated
recovery partition (select models only) on the hard drive. NOTE: A system restore needs to be performed if the computer hard drive has failed or if all attempts to correct any functional computer issues fail. A system restore should be used as a final attempt to correct computer issues.
Note the following when performing a system restore:
You can restore only the system that you have previously backed up. HP recommends that you use Recovery Manager to create either a set of recovery discs or a recovery flash drive as soon as you set up the computer.
Windows has its own built-in repair features, such as System Restore. If you have not already tried these features, try them before using HP Recovery Manager.
HP Recovery Manager restores only software that was preinstalled at the factory. Software not provided with this computer must be downloaded from the manufacturer's Web site or reinstalled
from the disc provided by the manufacturer.
Restoring using the dedicated recovery partition (select models only)
When using the dedicated recovery partition, there is an option to back up pictures, music and other audio, videos and movies, recorded TV shows, documents, spreadsheets and presentations, e-mails,
Internet favorites and settings during this process.
To restore the computer from the recovery partition, follow these steps:
1. Access HP Recovery Manager in either of the following ways:
Select Start > All Programs > HP > HP Recovery Manager > HP Recovery Manager.
- or -
Turn on or restart the computer, and then press esc while the "Press the ESC key for Startup Menu" message is displayed at the bottom of the screen. Then, press f11 while the "F11 (System Recovery)" message is displayed on the screen.
2. Click System Recovery in the HP Recovery Manager window.
3. Follow the on-screen instructions.
Restoring using the restore media
1. If possible, back up all personal files.
2. Insert the first recovery disc into the optical drive on your computer or an optional external optical drive, and then restart the computer.
- or -
Insert the recovery flash drive into a USB port on your computer, and then restart the computer.
NOTE: If the computer does not automatically restart in the HP Recovery Manager, the computer boot order needs to be changed.
3. Press f9 at system bootup.
4. Select the optical drive or the flash drive.
5. Follow the on-screen instructions.
Hope this helps you out.
Al
Oct 05, 2014 | Computers & Internet
Recovery discs aren't working on my hp cq60-615dx, what should I try next?
Appears that recovery disk #2 is bogus. U can try to get a new set from HP (fat chance!) or you can do a reload from a normal, retail OS disk.
Jun 17, 2017 | HP Presario Computers & Internet
My hp laptop with windows vista home premium is not booting and showing to insert bootable disk, which I don't have.how i can get this
The installed Windows in your laptop has been corrupted beyond repair - you will have to reinstall it.
For that pres F11 during boot to launch the HP Recovery Manager from the recovery partition then follow the instruction. If even that fails it means that the hard disk itself has failed - the disk will have to be replaced and to reinstall Windows you will have to order a recovery cd for your exact model from HP.
Jun 21, 2011 | Microsoft Windows Vista Home Premium with...
How can you reset a hp mini to factory default
you will have to use the restore function. because of it not having an optical drive
Oct 21, 2010 | HEWLETT-PACKARD HP Mini 110 101Inch Mobile...
Toshiba L350 series laptop shows "windows failed to start" screen when booting up & goes to a completely blank screen afterwards. Tried using recovery cd & can't get C prompt to come up. Need...
Shut down the laptop, make sure that no light is lit up. Before booting it back up, press and hold the F12 button. It will lead you to boot options. Open up your DVD drive and insert Disc 1 of recovery then make sure you select the ODD or the dvd drive to boot up. This will start the recovery process.
Other models has Icons for boot options. Make sure you select the single disc option to boot the ODD.
Hope this helps.
Dec 20, 2009 | Toshiba Satellite L350-ST3701 Notebook
When I boot I get as far as a screen that
Have you tried pressing F8 at boot time and booting in "safe mode". Then you can think of a solution.
Jul 27, 2009 | E-Machines eMachines Desktop PC
Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
My hpdv6000 recovery got stuck at 98% and showed 5 mins remaining then after 15-30 mins it moved to 99% and still showing 5mins! its been 30 mins no action seems its stuck. I started the process by going...
Hello Humanold,
Please check the following recovery steps:
Full recovery by using recovery partition:
1. Reboot the notebook PC.
2. Keep tapping F11 when the Compaq logo displays.
3. When the Recovery Manager appears, click Next.
4. When prompted to use the Microsoft System Restore program, select No and click Next.
5. When prompted to use the System Recovery, select Yes and click Next.
6. Select the option to perform the recovery without backing up files and click Next.
7. Upon completion of the process, recovery will display "The PC Recovery was successfully completed".
The recovery process will return your PC to the factory image.
Full recovery by using recovery disks:
1. Open the disc drive door and turn off the PC.
2. Insert the first Recovery disc in the disc drive and close the door.
3. Press the power button to turn on the PC.
4. The HP Recovery Manager window appears during the boot process.
If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before continuing the recovery.
If the HP Recovery Manager cannot access the hard drive to fix the system errors, the HP Recovery Manager will overwrite all the data and reconfigure the entire hard drive to its original condition.
5. Follow the prompts to insert any additional recovery discs in the disc drive.
Sep 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv8000z Notebook Logo
135 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
