Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
My boyfriend purchased a barracuda G3 2 days ago. After installing it worked really well for approx. 2hrs then the pressure increased to 20 eventhoug he had backwashed the pool and it was very clean. What is the probelm?
  • 990 Answers
Try backwashing again, this cleaner will pick up enough dirt in a couple of hours to clog the filter. Untill the pool is clean you need to backwash and check the baskets, (skimmer and pump pot) Probally two to three times in the first day, then once after a couple of days. After that you can get back to a regular routine.
Posted on Oct 03, 2009
How do I get a woman that is involved with another man 20 years her senior?
Move on sir. She is not interested in change. Set sights higher.
Nov 16, 2014 | Answerbag Relationships Q&A
The oil pressure is low at idle and rises with higher engine revs. Oil levels are ok, new oil approx 2000kms ago. Was a slight noise at one stage in the engine but went away after engine's revs in
It sounds as if the clearance that the bearings normally run in have been surpassed and need to be replaced. Higher engine revs will supply extra oil which will overcome any small discrepencies but constant running at this stage will result in faster degradation of all engine components concerned resulting in a more expensive repair. Shes basically worn out.
Feb 27, 2012 | 1993 Toyota Land Cruiser
I have a Craftsman (B & S) pressure washer 7 HP 2900 psi 2.3 GPM Model No. 580.752410. It's about 4 yrs old and 2 years ago I put a seal kit 193807GS into it after it failed to put out proper pressure....
I worked at a tool rental store while attending college and discovered how to extend the life of tools. Really a simple trick that you practice every day. Although your car can travel at a very high rate of speed, you only use about 30 to 40 percent of its power, if however you traveled at 100 mph everywhere that you needed to go, you would greatly shorten its life. Althouth I do believe that you have received good service from your unit, you may have increased the life by using only 60 to 80 percent of its pressure potential for most general work and increase only for stubborn debris.
Apr 26, 2011 | Briggs & Stratton Garden
Toshiba 52hm95 dlp needs color wheel. is it true that color wheel is no longer available as standalne part and entire liight engine has to be purchased? anyone know the approx cost of this part and source...
No it is not true that color wheels for this model aren't sold as stand alone you can find one on E-bay.The color wheel is approx $259.59 US.sorry don't know of a cheap place to install.Hope this helps you and have a nice day. loveindeath.jpg
Mar 02, 2011 | Toshiba 52HM95 52" HDTV Projection...
I have a 79 ford f-150 with a 351w modified engine. when i first start the engine it has approx. 65 psi oil pressure. as the engine warms up the pressure slowly drops off to around 12 psi.the oil is clear...
First off its not a 351W modified. you are confusing two different blocks. its either a 351 windsor or a 351m (modified) and if it is the modified its not that bad. these engines are notorious for having low oil pressure. at idle they can be anywhere between 10 and 40. as long as you gain 10 psi per 1000 rpm its fine. and a pump doesnt drop off as it gets warm. it either works or it doesnt, oil pressure dropping off is a bottom end bearing problem
May 20, 2010 | 1981 Ford F 150
Air Conditioning doesn't work, only blows warm air
Have your boyfriend check to make sure there is enough pressure using the refill kit you got. If your kit does not have a pressure guage, get one that does. Your A/C compressor will not kick in if the pressure it too low. If the pressure is good, then it could be a number of things.
  1. Low pressure sensor (need professional to replace)
  2. Bad A/C relay (located in fuse box in engine compartment. Can be swapped with another relay in the box to test)
  3. Bad A/C diode (located near A/C relay, need multimeter to test, of you can just replace)
  4. Bad A/C compressor (apply 12 volts directly to the device to see if it engages, if not, it's bad and needs professional to replace)
With A/C, there are so many variables, but this is a good start.
Mar 25, 2010 | 2000 Saturn Ls 4dr Sedan
Reddy heater 165,000 runs for approx 15 to 20 min. I unplug wait 5 min. it restarts again and runs for another 15 to 20 min. and so on ....and so on purchased approx 1 year ago
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
Jan 13, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Communication error 20
i think you have to install the opera mini browser in your device. i hope u will get the solution.
Oct 06, 2009 | Samsung SGH-A877 Impression Cell Phone
My Barracuda was working the other day before the
If your moving water it sounds like you have a suction valve that needs to be reset to the cleaner. If your main drain is plugged off as it should be with a suction cleaner, the pump will strain. Or it may be a plugged line. Check this by putting a small kitchen sponge it the skimmer and see if it gets pulled through to the pump basket. If it does not get there you have a plug.
Oct 04, 2009 | Zodiac Pacer Pool Cleaner
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
279 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
