Question about Canon PIXMA MX310 All-In-One Printer
Change colour FINE cartridge
How do I change the colour FINE cartridge?
5 Suggested Answers
  • 32 Answers
SOURCE: dont know how to change colour cartridges
Turn the printer on and open the lid. After a short while, the printer carriage unit containing the print head and ink cartridges will stop right in the middle of the printer, so you can easily replace the ink cartridges. After replacing them and ensuring they're fully seated, simply close the lid. The printer will run a few quick self-diagnostic checks and run a purge cycle, and it'll be good to go.
Posted on May 28, 2009
SOURCE: Red colour disappeared leaving just yellow and
bought a new printer ( the other was 12 years old)
Posted on Jan 21, 2010
SOURCE: trying to change colour cartridge
ok les cuento nuevamente tengo una impresora Hp photosmart C4180 all-in-one le instale el cartucho negro y el de color recargado o bien generico y me derramo por todas partes tinta incluyendo las tarjetas el problema que me esta dando es que no me enciede la pantalla ni mueve el carro donde van los cartuchos de tinta quesiera saber que puedo hacerle para resolver este problema ya que la desarme por completo la limpie todita y aun persiste el problema. me pueden ayudar por favor , Gracias
Mi correo es Dennisemilianofloresolivares@yahoo.com
Posted on Oct 13, 2010
  • 1196 Answers
SOURCE: Canon MP830 Any colour that is
I will suggest you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see what happens. let me know if additional information is required.
Posted on Jan 02, 2011
How do i change the colour cartridge for a epson style c42+ printer - if i press the red LED button for 6 secs only the black cartridge comes into the open.! how do i get the colour cartridge into view ?
after the black cartridge moves to the ink changing position, push the 'ink' button one more time to move the carriage to the position to replace the colour cartridge. in some cases this will only work when the printer indicates that the color cartridge is empty.
Oct 12, 2009 | Epson Stylus C42+ InkJet Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
Possible to print only black when colour cartridges are empty?
This printer does not let you print if even one of the cartidges is out of ink. I suggest you replace them and then in the printer properties change your settings to the way you want color to be spent.
Aug 04, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printing problem
it is a new original cartridge?
or u don't use it for a long time?
try to use a tissue press on the nozzle to see whether there r 3 colours on the tissue if there r means that u cartridge is spoil need to change a new cartridge.
if only can see red colour means that ur cartridge nozzle block maybe not use it for a long period, u may use a bit of warm water to clear it.
put some warm water in a container just 3-5cm high make sure the water do not higher than the circuit board on the cartridge, put the cartridge in for 5 to 10 min, use a tissue to clean up the nozzle and check the colour. most of the cases can be solve by using this way.
Mar 02, 2008 | Canon PIXMA iP1600 Printer
Magenta ink colour
I had the same problem. Try cleaning the print heads. They tend to clog. Remove the cartridges, then remove the print head. Tilted slightly, it comes out easily. Run very warm to hot water over the print heads until they all run clear. Use a turkey baster to apply strong pressure to each head until it runs clear. Blow off the excess water with mouth or blow dryer. Insert into the printer and proceed to print. If that doesn't solve it, you might have a bad cartridge, but there isn't much that can go wrong with the cartridge. I have an ip4200 and an MP830. They have the same print heads and same cartridges. I have cleaned each twice and they work like new.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
