Question about Tilia Foodsaver V835 Vacuum Sealer
Elitech vacuum sealer
The vacuum isn't working but the sealer is, both lights come on as normal, but the vacuum doesn't pump out the air
2 Suggested Answers
  • 87 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
How to Choose a Vacuum Packaging Machine?
When purchasing vacuum packaging machine, due to there are too much alternative models, people always become confused that how to choose a suitable vacuum packing equipment? Following analysis is conductive to your choice.
1.To determine the nature of products.
Different vacuum packaging machines are suitable for different products, some products with special properties, such as fluid, powder, granular and lump objects, etc., should not only satisfy the vacuum packaging function, but also asked to achieve better effects of vacuum packaging.
2. To select the appropriate vacuum packaging machine models.
Thinking about the function, vacuum packaging machine has many types, including ordinary ones, rolling ones, continuous stretch film ones and small vacuum packaging machine, etc, according to different production, people can select vacuum packaging equipment that fit themselves.
Different functions: Automatic stretch film packaging machine, single or double chamber vacuum packaging machine, automatic vacuum packaging machine, skin packaging machine, cassette vacuum packaging machine, rolling vacuum packaging machine, air switch installed packaging machine.
Different materials: all stainless steel, semi-stainless steel, ordinary steel, plastic spraying.
Different vacuum pumps: domestic special pump, imported vacuum pump, special vacuum pump. Imported pumps are more expensive, domestic pumps are relatively cheap, customers can choose them according to the practical situation.
3. Whether the power supply of workshop is suitable for vacuum packaging machine.
Some vacuum packaging machines apply to 380V power and some are suitable for the 220V power. If the power is too far away from the vacuum packaging machine, longer wires is required, and this situation may cause inadequate voltage, affecting production. Therefore, people should buy vacuum packaging machine according to the power of their factory.
4. Evaluate quality and after-sale service, etc. of vacuum packaging machine and choose cost effective vacuum packing factory, since this will reduce a lot of trouble for use.
5. Before purchasing a vacuum packaging machine, purchaser should consult with manufacturer on parts supply problems, to avoid delay in production caused by the malfunction of vacuum packaging equipment.
Dec 21, 2016 | Vacuums
It won't vacuum. Why?
vacuum sealer won't pull vacuum - GardenWeb
forums.gardenweb.com > Garden Forums > Harvest
Nov 9, 2008 - I know many of you use vacuum sealers, so hope you might be able to help. I have a FoodSaver Pro Sport, it's probably about three years old.
How to fix Food Saver - Vacuum Sealer? - Instructables
www.instructables.com/.../How-to-fix-Food-Saver-Vacuum-...
InstructablesMar 2, 2012 - I have a Food Saver brand Vacuum Sealer, that all of a sudden stopped ... If it won't heat up to seal the bag, then you probably have a break in
vacuum sealers - Frequently Asked Questions
Feb 03, 2016 | Kitchen Appliances - Others
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Why is my Foodsaver V2440 motor noisy while vacuuming bags?
This is normal it means that its just pumping air out of the bag but if it gets too loud and its not pumping air out of the bag then you might need it looked at soon
Jul 12, 2014 | FoodSaver V2440 Advanced Design Vacuum...
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Water does not drain 'Fast 40' and 'Delicate' lights come on to indicate a fault.
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | Hotpoint 24 in. FDW60 Free-standing...
The intake/drain light is flashing. I've removed the drain cover, but dont see any blockage
Hi
Thanks
Rylee
Nov 03, 2009 | Miele Touchtronic G894 SC Built-In...
My dishwasher keeps washing, doesn,t go through the cycles, i have to push cancel and drain.
Hi
Thanks
Rylee
Oct 27, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
How do I work a Salton vacuum bag sealer (Model BS-20)? I can not figure out how to get the air out of the bag.
This style of vacuum sealer has to use a special bag with a " dimpled " surface to let the air escape through the pinch jaws of the vacuum sealer.
The folowing web site has bags and rolls that can be cut ro make any size of bag you require. You can buy on line direct from the manufacturer as well as purchase more industrial vacuum packers
http://www.foodmc.co.uk/Category/113-textured-bags-for-external-bag-machines.aspx
Jun 14, 2009 | Vacuums
Tilia Foodsaver V835 Vacuum Sealer Logo
599 people viewed this question
Top Tilia Kitchen Appliances - Others Experts
Lee Eismann
Mike Squire
Ed Mac
Are you a Tilia Kitchen Appliances - Other Expert? Answer questions, earn points and help others
