Question about SkyCaddie SG2.5 GPS Receiver
Skycaddie 2.5 has white screen, when trying to turn on. I have disassembled and disconnected and reconnected the battery. Same thing.
Why does my monitor start as white when I turn it on? THe mouse pad does not work as well.
Monitor cable disconnected internally?
follow http://www.insidemylaptop.com/replace-screen-on-dell-latitude-e5420-laptop/
and disconnect, clean and reconnect ALL monitor related cables. (You may need a new screen if that fails)
You may check your laptop by connecting an external monitor first.
Aug 21, 2014 | Dell LATITUDE Computers & Internet
Sony vaio pcg 4a1l blank screen after replacing a new screen
Take it apart again, remove housings, disconnect cables, reconnect cables, and then power on. If that works then re-assemble
Oct 18, 2013 | Sony VAIO Computers & Internet
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My pc is showing a white screen when iys on
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
Help please, just replaced lid on emachines d620, all went well, just turned it on and screen is completely black. The logo shows very feigntly as it powers up, boots up fine but completely black screen.
It sounds like the cord connecting the lcd screen to the laptops motherboard has been disconnected. You will probably have to disassemble the screen portion of the laptop and reconnect the power wires.
Jun 28, 2011 | Computers & Internet
I only have a white screen,connect to another moniter still no screen.
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
1-laptop-white-screen.jpg Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
6-test-with-another-lcd-screen.jpg For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
7-white-lcd.jpg After I assembled everything back together and connected the original LCD, it's still white.
For more information:
http://solvetheproblemhere.blogspot.com/2011/05/laptop-lcd-screen-turned-white.html
May 10, 2011 | Samsung N150 Notebook
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
White screen only
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2007 | SanDisk Sansa e260 MP3 Player
SkyCaddie SG2.5 GPS Receiver Logo
329 people viewed this question
Top SkyCaddie GPS Experts
Joseph Hoffmann
Will Halftowaite
Are you a SkyCaddie GPS Expert? Answer questions, earn points and help others
