Question about RCA R52WM24 52" HDTV Projection Television
RCA 52WM24 COLORS SEPARATED, AND PICTURE IS BOWED IN MIDDLE
Last night, the set went black, then came back on, then went black again, then came on with the colors separated and a slight bow in the middle.I have set the convergence when I first installed the set, but now I have searched every page in the settings, and can't find the convergence settings anywhere. I read that someone said the convergence was dead, and to solder in a new kit? Could this be my problem, and whare is this located in the tv?
  • RCA Master
  • 8,457 Answers
Yes,convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.Also buy a DVD for instructions,never done this before,for safety reasons.Tries these websites Tv Repair World.com Or Ebay.com.
Posted on Sep 29, 2009
Sony kdl-32s3000 picture with no black
you might want to unplug the set and a box or receiver if used for a while==plug back and see if the units reboot helps this problem or not===a box or external unit can cause this kind of problem.
Jun 16, 2012 | Sony KDL-32S3000 32 in. LCD Television
50 inch rear projection hd ready model r52wm24 colors have separated and picture is bowed toward the middle top & bottom
sounds like the auto convergence option has disappeared from the set up menu. Press menu and scroll to setup and then enter setup menu and see if the auto convergence is still listed there or has it disappeared?
Jul 30, 2011 | RCA Televison & Video
Color separates and picture bows on 9 year old RCA big screen.
Hi, This is a convergence problem and you can set it right by changing the STKs. It is a professional job and i have knowledge of people who ruined their tv by spoiling some miniature surface mounted components close by. You may need to look at pico fuses too. I would say seeek professional help if you not comfortable working with electronics. Check out at www.fixurtvs.com,
Mar 02, 2010 | Toshiba 55H70 55" Rear Projection...
The colors separate and the picture bows in the middle
Ur convergence is dead,buy convergence kit.U know how to solder?Tries these websites.Tv Repair World.com.
Sep 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Picture bows in towards middle
YOU HAVE A ALIGNMENT PROBLEM, ON YOUR BOW OR PINCUSION, OR A BAD RESISTOR, THE COLORS NOT LINING UP COULD BE A CONVERGENCE PROBLEM. I ADVISE YOU TO LET A EXPERT TO THIS DUE TO THE HIGH VOLATE ON THE CRT(PICTURE TUBE)
Jun 07, 2009 | RCA Televison & Video
My camera screen is black.
If the new pictures are all black, then the problem is not on the LCD display, but it is a faulty CCD sensor.
The CCD image sensor is the device that captures the picture .
CCD sensor is covered even after warranty, contact canon ringing the phone number listed on the owner manual.
Mar 28, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA P52830BL picture is bowed and colors separated.
There is a convergence printed circuit board that likely has a few bad components. If you decide to get it repaired, the technican will probably check for fluid leaks from the picture tubes coolant area which has given problems on this model also. If the picture quality leaves a bit to be desired, it may be a wise move to upgrade to HDTV. A Sony KDS-55A20 model has a great picture and should be less than $2300. I just saw one at a local Sams Club store.
Mar 12, 2007 | RCA P52830BL 52" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
347 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
