Question about Vehicle Parts & Accessories
My scorpion alarm has stopped working, key fob not responding
I went out this morning and locked car using alarm fob, no problem, came home and tried to lock car , but my scorpion car alarm has stopped working, key fob light comes on when fob pressed, led light on dash not working. I am able to undo car with key in lock and can start engine with key . Fob wont open the car, alarm system seems dead, no shrieking from alarm when manualy opening doors with key , key will allow car to start, no kicking in of imobiliser. I have 2 fobs, neither will work, have checked fuses, all seem okay, car battery ok as ignition comes on, car starts This alarrm is 3 years old and cost a lot of money. Has it broken
  • 50 Answers
SOURCE: How do I program my remote control Fob for my 1997 Key Fob
1. Locate the Data Link Port. It is located under dash drivers side. Be sure you know which pins are 8 and 4.
(Notice port is wider on top row)
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a suitable
jumper wire (leave the jumper wire connected throughout the programming procedure). Make
sure you know which terminals are 8 and 4. The vehicle will respond by locking and unlocking the
doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be
programmed. After about 15 seconds, the vehicle will respond by locking and unlocking the doors.
Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be programmed.
5. Remove jumper wire applied to the OBDII Port.
Posted on Mar 16, 2009
jyackle5
  • 8197 Answers
SOURCE: pairing new alarm fob to cobra 777
Turn ignition key on and off around 5 times or till you here the alarm then hit the left and right button on fob till you here the alarm again then it is set. if you have 2 remotes you need to do them both at the same time.
Posted on Apr 07, 2009
SOURCE: 2006 Mazda 5 keyless remote fob
I am a technition for mazda, and if the lights are coming on to the keyfobs, the batteries are fine. What procedure did you follow?
1. Take key out of ignition
2. Shut all doors
3. Open drivers door
4. Insert key to ignition
5. Cycle between On & Lock 3 times, leaving key in Lock
6. Close and open the drivers door 3 times, leaving the door open
7. The Locks should cycle.
8. Press the Panic button on the remote twice.
Posted on Apr 29, 2009
SOURCE: Have 56 plate seat leon 1.6 .the alarm keeps going
I have Seat Leon 07 and my alarm has gone off loads of times in the last 18 months. The first time it was the window motor that went - went in under warranty and part replaced - it's now back in the garage getting the same problem fixed again. the neighbours are fed up with the alram going all times of the day and night. Hope this helps
Linda
Posted on Sep 18, 2009
dancandoit
  • 436 Answers
SOURCE: I have a Mitsubishi FTO with a cobra car alarm
hold down both buttons on the remote till they stop flashing, then press left then press right, this will recode the remote to the alarm. if this dont work try new batteries, if not then find an engineer.
Posted on Jan 03, 2010
Mustang alarm
Ford sold a Ford branded alarm through the parts department. These sometimes were a dealer installed option on new cars. Mine would randomly stop responding to the remote and I would have the same symptoms as you describe. I had it removed and the original equipment factory system still worked. Be warned, if you have the Ford "accessory" alarm, your key fobs (remotes) are different and the method to program them is different from what you will read online. You can tell if you have the system by looking at your key fob. The standard Mustang key fob is a 4 button (lock, unlock, panic, and trunk). The accessory alarm uses a 3 button remote and clicking unlock twice would pop the trunk. I really wish I had a picture of the remote because there are 3 button Ford key fobs for cars without a trunk release although I don't think you should have one on a Mustang. Long story short, if you have the accessory alarm, you can solve your problem by having it removed but you will need new 4 button key fobs to remotely lock/unlock your doors
Apr 04, 2014 | 2003 Ford Mustang
Security alarm problem
Replace the alarm system cos your Harley has probably shook it to death!! Genuinely!!
Mar 13, 2014 | Harley Davidson Motorcycles
Vw passat 2006 slow to start this morning and this afternoon alarm went off when i locked the car and took 10 seconds to stop
Sounds like the battery or a short in the battery line. The VW alarm will come on if you disconnect the battery. Use a voltmeter (or mutlimeter) to check the battery voltage (red lead on positive pole; black on negative; range on 0-50V). When car is not running, you should see 12V; when car is running, you should see 15V (if the alternator is working). You can also test the battery charge by turning on the headlights. If they brighten when you rev the engine or if the dim when you turn on other electrical accesories, then it is likely the battery.
Jan 30, 2014 | 2006 Volkswagen Passat
Immobiliser fault
Spelling was fine, along with grammar and punctuation-you should see some of the mangled illegible questions we have to decipher, or try to!
But thanks for the follow-up on your problem and the solution. Who would have thought was just the battery? Responses like yours are great encouragement to keep going.
Jun 10, 2012 | 2005 Citroen Xsara
Went to hospital parked car came out key fob not working opened key fob two of the sensors had come off.Managed to get it working to get home.went out to car with spare key fob but did not work opened key...
Im not sure there is any easy fix for this so I will just give a little advice.
Can you give me the make and model of the car? and is the alarm and immobilizer a standard factory one? Will do my best to help you once I know the make and model, and the year please.
Regards
Dan
Nov 07, 2010 | Vehicle Parts & Accessories
When we use our key fob to lock the doors, i know we must use the key fob to unlock the doors to avoid the alarm from going off. Recently I parked in a parking garage at an airport (left key fob at home)...
You should be able to just unlock the door with the key, and even if the alarm is still going of try to start it the key should override the alarm.
Sep 15, 2010 | 2001 Toyota Tundra
RS Focus registered yesterday 19th March Keyless entry but remote fobs do not lock or unlock car. The car was driven back yesterday hav ing now covered 114 miles alarm was going off last night but thats...
should not be using fob buttons for entry or locking for emergency only .if keyless entry walk up to car with fob do not press any buttons see if door opens then walk away from car with fob about 20m then go back to car without fob and see if door locked if so all working fine .indicators will not flash if the above dont work take back to main dealer for diagnostics keys may need to be reprogrammed
Mar 20, 2010 | 2009 Ford Focus
Alarm won't stop sounding
Hook the battery back up. It may of shut off. If not the battery in your fob may be dead. Wait for your husband to come home and use his.
Jul 15, 2009 | 2006 Toyota Tundra
Mercedes c220 ignition key stopped working
Hi! Sounds like the key needs to be coded again, take all relvant details i.e. chassis vin number, Registration document (Title) and key to your local Mercedes Dealership and hopefully they'll rec-code it for youor replace it.
Good Luck and a Happy New Year to You and your family.
Remember the blue FixYa button?
Paul 'W'
Dec 29, 2008 | 2001 Mercedes-Benz C-Class
Vehicle Parts & Accessories Logo
1,075 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
