Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Must push choke in periodically to keep it running. it's a remote control, and you choke it by pushing in the key. mod#; bj35vl3sie. 2 stroke.
  • 86 Answers
Adjust your idle mixture screw. If that doesnt work then run the engine at high rpm's and push the choke in until it is about to die and let off. This will create a vaccuum in the carb and possibly **** out any particles in your jets. If that doesnt work then I would rebuild the carbs.
Posted on Oct 16, 2009
Start OK but if after warm up I push the choke to run, the engine stops, I used 4 time before and idled OK
Push choke to run???then not use on a all ready warm engine you mean you push the GAS lever ? remember a choke can work as a throttle for the engine. it can have a double function if your electric start contact is damaged you can use it to stop the running engine also.
How long you are owner of the machine , read the manual about it !
If before it worked good on this kind of proceedings as described ? then if you mean you push the gaslever to run Try it to do it again without the airfilter. I THINK YOU HAVE An AIR problem by carburator if its so clean the airfilter if its not to old. or replace
You can use for short time the choke in most cases minimize use of the choke short not more then 2 times max you pull.or electric start.
AND very important control in any case allways for THE RIGHT OIL level !!
If the engine is warm(hot) do not use the choke forget it it has no use. control your spark plug electrode i think you will find the cause.
Oct 12, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
REVS HIGH WHEN FIRST CRANK IT, GETS HIGHER WHEN PUSH CHOKE DOWN. RUNS OK AT HALF CHOKE.... TRYING TO SELL IT, RAN FINE HAS JUST BEEN SITTING UP FOR A YEAR. PLEASE HELP!?
Hi, Anonymous and the usual suspects are:
1. Throttle cables improperly adjusted or pinched.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Dirt Rider Magazine
YZ 125 Climbing high idle Yamaha 2 Stroke
How to Get Your 2 stroke Idle Perfect YZ125
Yamaha YZ125N1 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Feb 17, 2014 | Yamaha YZ 125 Motorcycles
2007 Yamaha 115 Hp 2 stroke idle problem
Check the idle mixture. Sounds to me like it is too lean.
Mar 20, 2017 | Clymer EvinrudeJohnson Outboard Shop...
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
Remote control has stopped working. Have tried changing the battery of the remote control but that did not work.
Does the red light on the remote light up when you push any of the button
if no, replace remote
if yes, then try repograming the remote to the car again.
-Have remotes' ready. if you have two then fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 8)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes' should work again.
good luck
Dec 17, 2010 | 2003 Honda Accord
How do you start a 2 stroke Mantis? I lost the book. Will
first, push the primer bulb a few times to get fuel circulated and air out of the carb. Turn on the switch, put the choke on full. Pull the rope until you hear it fire. Then put it on half choke. Pull the rope; it should fire within a few pulls, and should run. Take the choke the rest of the way off once it's running well. This is a standard starting procedure that works well for every kind of 2-stroke engine used in the garden.
Mar 28, 2010 | Mantis 2-Cycle Tiller
Poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
http://www.drystacked.com
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Feb 18, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a 1993 2 stroke 40 hp mercury outboard motor and it seems that whenever you start it you need to use the choke, even when it's been running for some time and warm. Is that normal for these motors?...
Use it .It is a common thing with 2 strokes.Outboards have water in them and cool down quicker than say a 2 stroke motorbike. They have no water and keep the heat in the engine longer.If it runs well,,don't spend the money.All the choke does is gives the motor a slightly richer air/fuel mix at startup.It cannot hurt the motor.Hope this helps
Jan 05, 2010 | Boating
Can not program remote rca rcu600m when i push device key noting
yes you are right must blink but read the manual you should maybe keep pressed onter button first like shift or code something and then to enter the code
Dec 10, 2008 | RCA RCU600M Remote Control
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
252 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
