This one is carrier AC with bad blower motor. Hope This Helps.
Sounds like bearing is out on motor or blades on motor are out of balance you may have to replace both it can also be bearings in the evaporator motor if its a package unit or even something caught in the evap squirl cage.hope that helps you
sounds like bearing is out on motor or blades on motor are out of balance you may have to replace both it can also be bearings in the evaporator motor if its a package unit or even something caught in the evap squirl cage.hope that helps you
What kind of noise ? May b from motor/Compressor. Did u check the noise where it comes from ?
