Question about Brother IntelliFax-4100e Fax
NUMBER OF FAXES THAT IS GOING THROUGH
I SCAN AND FAX 37 PAGES AND ONLY 18 GOES THROUGH. IT THERE A WAY TO CHANGE THE NUMBER OF FAXES ALLOWED TO GO THROUGH AT ONCE
  • 748 Answers
This might be a limitation on the receiving side - some faxes have such limitations as a poor man's "anti-spam" measure...
Posted on Nov 07, 2009
Need to print a fax in memory, machine was turned off and unplugged
It may be too late to print the faxes if your printer was unplugged. But you can try:
reprint the faxes in memory
Your HP OfficeJet can store a limited number of fax pages in its memory, with
the number of pages depending on the model you purchased. When your
HP OfficeJet runs out of memory to store faxes, it will not receive any more fax
calls until the stored faxes are printed.
Reprint Faxes in Memory enables you to reprint a fax stored in memory. For
example, if your print cartridge runs out of ink or paper becomes jammed when
printing a fax. This option prints all faxes in memory; press Cancel to stop
printing faxes you do not need.
1 Press Menu.
2 Press 2, then press 3.
This selects the Fax Functions menu, then selects the Reprint Faxes in
Memory
option. The faxes are printed from memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I wanna send a fax
Sending Faxes.
* Flow of Sending Faxes.
The operation flow of sending faxes is as follows.
Step 1:
Load the original to send on the Platen Glass or the ADF.
Step 2 :
Adjust the fax quality and scan contrast.
Step 3 :
Dial the receipent' s number.
Step 4 :
Send Faxes
- Using the Platen Glass
1) Press the Color or Black button.
If you have two or more pages of the original, load the next page on the Platen Glass and press the Color or Black button
2) After scanning all the pages of the original, press the OK button to send the fax.
- Using ADF
The fax is sent automatically.
* Before sending Faxes
- Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
** Adjusting the Scan Contrast
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among the 3 contrast levels.
1) Press the FAX button, then press the FAX Quality button.
2) Press right or left arrow ot select the contrast.
Pressing the left arrow button decreases the contrast, and pressing the right arrow button increases the contrast.
3) Press the OK button.
** Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
1) PRess the FAX button, then press the FAX Quality button two times.
2) Press the right and left arrow keys to select the resolution.
FAX RESOLUTION - STANDARD
Standard : Suitable for text-only documents.
FINE : Suitable for fine-print documents.
PHOTO : Suitable for photographs.
*Sending Faxes - There are 4 methods for sending functions
a) Memory sending
b) Manual sending
c) Dialing the coded speed dial
d) Redial
a) Memory sending
1) Prepare for faxing
a) Turn on the machine,
b) Load the original on the Platen Glass or the ADF.
Note : You cannot scan double-sided documents from the ADF.
c) Press the FAX bitton.
d) Adjust fax settings as necessary.
2) Start faxing.
a) Dial the receipient's number using the Numeric buttons or coded speed dialing.
b) Press the Color button for color sending, or the Black button for black and white sending. I
c) When the following message is displayed, lad the next page on the PLaten Glass.
Scan Next -> Start
Transmit-> OK
If only one document go to step f).
d) Press the same button as you pressed in step b).
e) Repeat step c) and d) to scan in all pages of the document.
f) Press the OK button.
Manual Sending
1) Connect a telephone to the machine.
2) Prepare for faxing.
a) Turn on the machine.
b) Load the original in the ADF,
c) Press the FAX button.
d) Adjust the fax settings as necessary.
3) Lift the handset of the telephone connected to the machine.
4) Dial the receipient's number on the telephone.
5) Talk through the handset to the recipient.
If you hear a high-pitched signal instead of the recipient's voice, go to step g),
6) Ask the recipient to set recipient's fax machine to receive faxes.
7) When you hear a high-pitched signal, press the Color button for sending color sending, or the Black button for black & white sending. Then hang up the handset.
Dialling The Coded Speed Dial
1) Prepare for faxing.
2) Press the Coded Dial button.
3) Press the Numeric buttons to enter the two-digit code (00-19) assigned to the number you want to dial.
4) Press the Color button for color sending, or the Black button for black & white sending.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Nov 27, 2009 | Canon PIXMA MX310 All-In-One Printer
All faxes are not received when scanning 37 pages.
I am attaching a copy of the manual that tells you everything and how to set them up.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000400/ALLFAX_UsaEng_PrinterUG.pdf
Sep 29, 2009 | Brother IntelliFAX 4100e All-In-One Laser...
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Not pausing to acknowledge
Open up the feeder to see if a piece of paper is holding a switch actuator down.
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
FL511'S Faxes using Quick Scan
Search thru your menus to make sure GROUP DIALING and CHAIN DIALING are not enabled.
Sep 24, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
HP 1020 fax
From manual: Insert document; press Scan & Fax button; dial number; press Start/Copy.  All pages will be scanned, number will be dialed, and scan will be transmitted.  If Memory Full displays, repeat procedure without using Scan & Fax button.
Jul 15, 2008 | HP 1020 Plain Paper Thermal transfer Fax
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Does not scan pages until it makes connection
yes, the solution is that you are direct sending the faxes instead of scanning into memory which will start and complete the scan of all the pages as it begins dialing and transmitting. there should be a key on the control panel for memory or memory transmission, select it and your done.
mikey
Mar 14, 2008 | Brother IntelliFAX 4100 Laser Fax
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
Brother IntelliFax-4100e Fax Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
