Question about Sport & Outdoor - Others
I need to learn how to winterize our 2006 yahama waverunner. the model is fx high output. thank you.
  • 770 Answers
Drain the engine
Get ready to store your personal watercraft for the off-season months right after you take your final ride of the season.
The first thing you'll want to do when you take your PWC out of the water is drain the water from the engine. The best place to do this is right at the loading dock when the craft is out of the water and the trailer is tilted so the stern is lower than the bow.
Start the engine a few times letting it run for no more than 30 seconds to prevent the engine from overheating. While the engine is running, turn the handle back and forth. This drains any excess water out of the engine.
Clean It Up
Take extra care to thoroughly clean your PWC one last time.
Wash down the exterior of the craft using the same kind of soap that you would use to wash your car. It might take some extra elbow grease to remove all the build-up, but removing the algae and grime now will be much easier than trying to clean it off after the storing period.
When you're finished cleaning make sure there is no water in the hull, and the interior and exterior of the watercraft are completely dry.
For extra protection on the exterior, finish your wash with a wax job and use a light coat of multi-purpose lube to coat any metal surfaces such as latches and hooks.
Gas It Up
Fill up the gas tank to prevent condensation over the storing period.
Top off the fuel tank with the appropriate amount of gas stabilizer, according to the instructions on the container. Using stabilizer prevents the gas from getting gummy, which can eventually clog the carburetors and make for a messy problem.
Start up the engine a few times for no more than 30 seconds. This not only allows the stabilizer to work its way through the engine and the carburetors but will drain any excess water out of the engine as well.
Remember to be cautious of where you store the PWC with a full gas tank since gas is extremely flammable. Storage near any heat source or source of sparks is very dangerous.
Oil It
The next step is to spray fogging oil through the carburetors and spark plug cylinders.
Begin by removing the air cleaners. This will allow you to spray the oil directly into the carburetor throat.
Start the engine and spray the fogging oil into the throat of both carburetors while it is idling. Continue spraying until the engine stalls and then replace the air cleaners.
Next remove the spark plugs, making sure the wires are grounded, and spray fogging oil into each hole for a couple seconds.
Place a rag over the holes and push the start button of the craft. This will not start the engine but will allow the oil to coat and disperse internally. Clean any oil that may have dripped and then reinstall the spark plugs.
Remove the battery
Check your battery and battery chargers for specific safety instructions.
Remove the battery by first disconnecting the negative terminal followed by the positive terminal.
Store the battery indoors in a warm place such as a shed or garage. We do not recommend storing the battery in your house, as it can give off dangerous fumes.
If the battery case is older, place the battery on a rubber mat for storage. Placing an older battery on concrete may cause the battery to conduct a current and eventually discharge it.
Attach the battery to a trickle charger and remember to check the battery water level every month throughout the storage period.
Storage
Because your craft will have a full tank of gas, remember to be cautious about the location that it will rest.
Put your trailer in a level position in the place where you intend to store the craft. The best way to prevent flat or corrupted trailer tires over the storing season is to take the tires off, store them indoors and use concrete blocks or a jack to hold the trailer in position.
If you choose to leave the tires on, cover them with tarps or durable plastic bags. To prevent rotting, place boards under the tires if the ground is gravel or dirt. Once the trailer is in place, unlatch the seat of the PWC to allow air to circulate through and prevent any moisture from being trapped inside.
Place steel wool or a rag inside the exhaust to prevent any animals or bugs from nesting there.
Finally, place your cover over your PWC to keep it clean and protected while it's being stored.
Posted on Sep 30, 2009
Yamaha 1100 waverunner
they dont do a 4stroke 1100 high output ! 1800HO then 1800SHO !
Aug 08, 2014 | Boating
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Waverunner fx high output jetski how to unlock without remote
ask the dealer as i have no idea and i would imagine that its like a lot of modern cars its a dealer only job to make more work for them with fancy electronic controls thats using encrypted software
Dec 24, 2011 | Yamaha Boating
03 yahama fx 140 waverunner smoke coming out of water pilots and will only go about 25 to 30 mhp normal is about 60
I was raised on a marina and worked at the waterfront for quite a while. I had wave runners, jet skis, boats, you name it.
Whew, that sounds serious. You probably need to take it to the shop and let them run some test on it. Your problem is bigger than myself.
Apr 11, 2011 | Yamaha Boating
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 | Boating
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Jul 28, 2009 | Yamaha 12V Air Pump
Speed tops out at 20 mpg
new yamahas are bad for fouling plugs instead of cr9eb use cr8eb they are hotter and seem to work better make sure you change the battery in the remote if that doesnt work its the plugs
Jun 15, 2009 | Yamaha 12V Air Pump
Sport & Outdoor - Others Logo
132 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
