Question about Black & Decker Saws
I have a navigator saw that the part that holds the blade broke. I have the new part but cannot figure how to install
  • 2,176 Answers
Go to Dewaltservicenet.com and type in your model number for a parts explosion that should show you the installation.
Posted on Oct 06, 2009
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
The blade broke off inside and I can't get it out. Please help me figure how to get it out.
moden jigsaw blades are held in with a taper chuck system
disconnect the unit from the wall socket
push the spindle all the way in
now press on either side of the blade holder and that should move down releasing the blade
now while holding that section down turn the unit right side up and the broken bit should just fall out
Oct 13, 2015 | Skil 4495-01 6 Amp Orbital Jigsaw
How do you install new blades on a DW7332?
unplug the saw/remove battery
press the button on the side near the blade
pull old blade out. push new blade in, release button to lock new blade in place.
Jun 06, 2014 | Saws
I am trying to replace the blade in my scroll saw because the other blade broke and I can't seem to figure it out. Any suggestions?
Manking an assumption that yours looks like this one below?
If so, you'll need to flip up the yellow catch to release the jig blade. Sometimes they get a bit stiff, so wearing gloves try and waggle the blade free. There is normally a tensioner at the back that guides the jig blade (like a roller) that can also be loostened off to get the blade out
Install is reverse of removal
If this helps, pls leave feedback, if not let me know and I'll try and help some more!
Jan 27, 2010 | Ryobi Saws
How do I remove the blade from a Makita MK470 tile saw? I can't figure out how to hold the saw blade so that I can turn the nut hodling it on. The nut is on pretty tight and I need to lock the blade so I...
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
Nov 11, 2009 | Saws
My blade broke off in the lock of my craftman scrolling sabre saw and I can't get the part that is left inside out. Therefore I cannot put a new blade in. Is there a way to fix this?
Take off the clamp that holds the blade in place. Use a good degreaser (Electronics quality is best, it leaves no residue) and spray it into the blade holder. Next, blow it out with compressed air. The blade should be easily "bumped" out now. Oils & dust residue will hold the stub in, until you clean it out.
Oct 20, 2009 | Craftsman Saws
How do I remove the blade and reinstall a new blade in my Navigator saw. Thanks.
Before you can mount a new blade onto your black and decker navigator you must make sure the holding pin, (the flat side of the oval part) is paralell to the bottom of the saw. If it is not push the black button that pushes the pin out as hard as you can and with a small wrench move it into the proper position. Mount you blade @ 90 degrees and push it up into position
Oct 01, 2009 | Black & Decker 11-3/4" Navigator General...
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
How to change blade
remove the blade guard, should be a big nut holding on blade remove that nut install new blade, make sure the rotation arrow on your new blade is going same direction as old blade reinstall the big nut and washer , put guard back on you should be set! good luck
Mar 24, 2009 | Dewalt D24000S Wet Saw With Stand
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
Saws Logo
244 people viewed this question
Top Black & Decker Saws Experts
Ruben Bustamante
Jason
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
