My Kenmore All in one does not shut off the water after filling starts. It has even run water into the tub and over filled when not in use. Could it be the mixing valve?
    President:
  • 1,776 Answers
I would suspect a faulty water level switch. This is a diaphragm type device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water. Make sure there is no damage to or obstruction of the plastic tube. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity would indicate a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 29, 2009
    Problem Solver:
  • 16 Answers
All DW's have an electro-magnetically operated water inlet shut off valve. If the valve leaks, the DW will overflow when not in use. Also check that the electrical connectors are tight & show no signs overheating. There is also 1 or more, float operated cutoff switch(s). They are anti-overflow switches that make the water inlet shut off valve close to maintain the correct water level.
They are float operated, if the float-switch binds or sticks, the water level can be allowed to get too high & result in an overflow when in use. So they are usually a good place to start solving the problem when the DW is "leaking". Of course check all hoses & connections as well, a leaking connection usually has a crust or marks from leaking.
KENMORE DISHWASHER, WATER CONTINUES TO FILL AFTER WASHER IS SHUT OFF.
You're correct you have a faulty water inlet valve. At the end of the wash cycle the solenoid in the valve is not closing properly to not allow water to re-enter the tub. For further assistance with this repai
Jan 21, 2014 | Computers & Internet
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
WATER FILLS WONT SHUT OFF
The pressure swith (load size) is what controls that chang that. A small hose runs from the bottom of your tub and as the water fills a measerd amount of water fills that tube and pressure build up in their operates that switch and activates the timer to stop filling and start agitating.
Jun 06, 2010 | Kenmore 24032\24036 Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Water fills up in tub but wont shut off flooded
Sounds like a problem with either the inlet valve or the pressure switch, the way to determine which is bad... while the machine is filling pull the power plug..if the water keeps filling it's the inlet valve that is going to be bad..if it stops filling it's going to be the pressure switch. The pressure switch is located in the control panel and has a small rubber pipe attached.once you have figured which it is replace it good luck.
If you have any other questions or concerns please feel free to comment again..Mike
Jul 25, 2009 | Kenmore Washing Machines
My kenmore top load washer keeps filling, watere
the fill valve is bad or there is a hole in the tubing that attaches to it, this tube goes from the pressure switch to a bulb on the side of the tub only air pressure goes through this tube one small mouse bite and it is damaged
Jul 06, 2009 | Kenmore Washing Machines
Tub overflow
Remove the hose from the water level switch and blow air through it.
The water level switch air hose has a clog in it.
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
