Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anyone know how can i calculate 1.0595 to the -2.5 power?
Anonymous
Level 3:
  • Master 496 Answers
  • Posted on Sep 29, 2009
Anonymous
Master
Level 3:
Answers
496
Questions
Helped
217425
Points
1478
Here is an operators manual that should help you.
http://education.ti.com/downloads/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
It's a PDF document. You can search the word "powers" and find all references to using these notations.
I don't have a TI-84. I used my PC calculator with the button x^y ....... 1.0595 {x^y} 2.5 {+/-} ..... to obtain:
0.86546118972999206534043790630855
Check me... please... ha
Hope this helps...
7helpful
Need to know how to power a number???
You can use the universal power key. On the screen capture it appears below the hyp key (second row, the one before last)debc9eb.jpg
To enter 1000 to -.415
1000 [y to x] [(] [+/-] .415 [)]
where [+/-] is the change sign key.
2answers
Would not power up.
Having gone over a month with no response, I assume this is no longer a problem.
I'm trying to find 1.00026712 to the 1825th power. I tried it with the y to the x function and it said error. does anyone know why?
I see no reason why you should not be able to calculate that power. The result, as expected is close to 1, in fact 1.62812476. It is more likely due to a manipulation error on your part.
Try to calculate 1^(1825). If you do not get an error, then it must certainly be a manipulation error. To make sure you do it correctly, here is the correct syntax.
1.00026712 [Y to the x] 1825 [=].
Hope it helps.
Thank you for using FixYa.
To the power of...
There must be [ ^ ] or [ y^x ] button it's the function of the power so use it like this: x power y
Rate me, thanks.
RAD
Change the angular mode to something other than radians.
2answers
Who Repairs them?
calculators are repaired in watch works...they will give u a better service for calculators...if it s scientific calculators..then giv it to the computer service providers....but usually there s very few service providers can been seen for repairing the calculators...since it doesnt cost much!!!!
17helpful
3answers
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
