Question about Sanyo DS19330 19" TV
Wont turn on
I changed the fuse inside but it still wont work for me any easy ideas?
    Genius:
  • 1,694 Answers
Check Horiz Output transistor and we go from there...T.
Posted on Dec 19, 2007
My bush CHT101DVD subwoofer wont turn on, it was working then all of a sudden it made a buzzing noise and turned off and now it wont turn back on, i changed the fuse in the plug but still nothing so i...
Subwoofers are just mono amps. It sounds to me that the thing that does all the work (the power amp section) has blown, killing the fuse inside. Opening it up will show any fuse. But I would bet on it going again if you replace it only.
Jan 06, 2018 | Audio Players & Recorders
My turn signals, horn and brake light all quit working. I don't have a manual so I am not sure what fuses to check or if it is even a fuse problem.
getting a manual would be a good idea - fuses are under the right side cover or under your seat - usually very easy to tell a smoked one as its contacts inside are either broken/ burnt or gone
Mar 25, 2012 | 1998 Honda VT 1100 C3 Shadow Aero
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
Presonus firebox wont turn on
Get a flash light,look inside at the battery pack's connections(1) And then see if there's rust,a dull appaerance to each spot where the battery connects(2)Go to a radio shack and see if they have an equivalent fuse,and a manual for the fuses installation(s).Get Presonus online,and/or write them aletter about thier devives problems.
Feb 15, 2010 | PreSonus Firebox 6x10 External Sound...
No power
Sounds like the internal 1.6 amp fuse has blown. Its quit easy to change, check the replies I've sent to get access to the unit and the internal fuse.
Oct 04, 2009 | Bose Lifestyle 12 System
Kenmore dryer model 64602 wont turn on???
Check the thermal fuse on the rear of the dryer.
Remove the rear panel. The thermal fuse is 1 and 1/2 inches long by 1/2 inch wide. White in color and located just left of the dryer exhaust vent. 2 purple wires. Jump the wires together and start the dryer. If it runs, replace the thermal fuse.
May 25, 2009 | Kenmore 73952 Gas Dryer
1.5dci 2004 scenic wont start
hi is there fuel getting to engine?any vapour coming out exhaust?sometimes glow plugs not working can cause this.try a squirt of easy start into air filter.NOT MUCH!!READ INSTRUCTIONS.HIGHLY FLAMMABLE.then start car for about 10secs.get this from car accessorie shops.if it fires on this its highly likely glowplugs not working or fuel pumptiming out.its hard to say without seeing the car
May 18, 2009 | 2004 Renault 181
Fog lamps
a bad relay is your most likely cause.  It's inside the fuse box.
Mar 06, 2009 | 1994 Ford Mustang
Brake light
I would consider a wiring or socket issue. Check the points where the bulb makes contact and clean them and make sure they are making contact. If you have a volt meter this will be very easy to solve
Feb 01, 2009 | 1990 Buick Regal
120v Bose Wave Radio/CD player plugged into 240V outlet
there is a fuse inside but after changing the fuse if it still dont work the rectifier could be bad.
Jan 13, 2009 | Bose Wave Radio
Sanyo DS19330 19" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
