Question about Kenmore 800 7983 Dryer
Kenmore 800 series gas dryer won't stay hot
A Kenmore 800 series gas dryer that heats up a litttle to start a load, but eventually cools. If you let it rest a day it seems to stay a little warmer longer. I've unclogged all vents so that's not the issue. Is this a thermostat or coil issue? Any recommendations on where to get parts? Does a fool like me dare to DIY?
  • 18 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
If gas is available after burner ignition for 3 - 10 seconds but then cuts out, this is an indication of a (1) lint clogged exhaust line,or (2) a fan suction bypass leak, both of which are resulting in insuffucient burner cone air/gas flow. Insufficient burner air flow results in actuating the high temperature limit thermostat or thermoswitch (usually a L220-40F thermostat) mounted on the topside of the cone. With inadequate cone air flow, burner flames are directed upward toward the thermostat instead of being pulled into the cone and then into the hot air supply for the dryer drum.
For (1), clear the exhaust line from the lint filter to the discharge louvers on the exterior of your home. Access to the backside of the dryer is necessary.
For (2), check the lint filter to fan suction connection for any possible leak paths. Access to the front interior of the dryer is necessary.
For a DG512, the front assembly that houses the lint filter and abuts the front end of the drum has a short duct that fits into the suction side of the casing for the squirrel-cage fan. This duct has a tendency to separate from the fan casing (its a slip fit) resulting in bypass leakage. If suction bypass leakage is occuring, this is air that is not being pulled through the drum, and hence, is not being pulled through the burner cone. As indicated above, a low cone air flow results in actuating the high limit thermostat, which then deenergizes the gas coils cutting of gas to the burner.
Note: These symptoms are NOT indicative of failed gas coils, since gas is being supplied initially to the burner for a period of 3 - 10 seconds. If the coil(s) have failed, the burner could not operate for any duration.
Posted on Oct 04, 2009
SOURCE: Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Posted on Oct 06, 2008
  • 1214 Answers
SOURCE: Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Posted on Jan 19, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore 80 series Dryer: Door Light stays on and wont start
Posted on Mar 05, 2009
  • 44 Answers
SOURCE: Kenmore 70 series gas dryer does not ignite I
Check for burnt out glow ignitor. If okay then check thermal fuse and all other thermostats with ohm meter..... all must be in closed position.
Posted on Mar 21, 2010
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
Kenmore 500 series dryer blows cool air only
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 10, 2010 | Zanussi TC180W Electric Portable Dryer
I HAVE A KENMORE 80 SERIES GAS DRYER. IT WORKS
Yes the moister sensor is at fault
Apr 29, 2010 | Dryers
Heat does not stay on
Check the high limit thermostat. You can check it using a multimeter or ohmmeter. If bad, replace it. Hope this helped.
Jul 18, 2009 | Kenmore 800 7983 Dryer
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Mar 05, 2009 | Kenmore 800 7982 Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
Heating on series 70 Kenmore Gas Dryer
suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Nov 26, 2008 | Kenmore 70172 Gas Commercial Dryer
Not staying hot-Kemore 80 Series gas
suspect coils bad on burner valve after heating up first time will sometimes fail on following fire ups
Nov 19, 2008 | Kenmore 63942 Dryer
Kenmore 800 7983 Dryer Logo
602 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
