Question about BenQ LCD Power Adapter for FP951 Monitor
FP531 Computer monitor operational manual
My screen is off centre and I can't find the manual to operater the monitor controls. There is also a blue box in the centre of the screen that says, "Out of Range!" What is that?
  • 383 Answers
Monitor Help The size is an important factor of the computer's running resolution. When picking the resolution.
Cant find your maual on sites, contact your computer manufactor for the maual.
Posted on Dec 19, 2007
Black monitor screen fp51g q5t4
> Check Windows proper running or not.
> Have a HDD problem, so check it.
> Check keyboard num Lock coming light or not. If not coming light then RAM problem.
> If all thing is ok then change monitor scree.
Sep 05, 2013 | BenQ FP531 15" LCD Monitor
My monitor was working for a while and now the screen is black but the monitor is on and the screen flashes the desktop but only for about 1 sec then goes black again how do i fix this problem
Check the caps for leaking/bulging tops first.
It can be power supply, backlight inverter circuits problems.
Basic LCD monitor and TV troubleshooting guide:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 10, 2010 | BenQ FP531 15" LCD Monitor
Have moved and connected back up, Monitor message in middle of screen OUT OF RANGE
check the cable be connected in the right post ..if you have a video card and a on board card might connected it by mistake in the on board card port ..and this one is disabled cause you have another card on a Pci port...
another issue may be from the plug itself...try to move them cause this message is received only when it do not gets signal
Jan 29, 2010 | BenQ FP531 15" LCD Monitor
The problem is a mssg in the midle of the screen frecuency out of interval
Have recently moved and after connection, a message in the middle of screen OUT OF RANGE
Oct 14, 2009 | BenQ FP531 15" LCD Monitor
Blinking BENQ FP531 continuosly...
you probably have a loose wire in the unit, you might have a bad vga cable, except for the vga cable, you will probably need to send it in for service.
Apr 18, 2009 | BenQ FP531S (Silver) 15" LCD Monitor
On startup the screen shows ( out of range )
It means your system display card settings are too high for your monitor. Boot your system into safe mode and set the display settings lower. Right mouse button click on an empty space on your desktop and go to properties. Then settings->advanced and you should be able to adjust the vertical frequency down to 60hz or 72hz. If not, then go to the monitor tab and load a generic monitor driver.
One time, I bought a repackaged display card that had been set too high and I had to reload the card driver in safe mode to get it to work correctly.
pls rate my solution
thankyou for using fixya
Feb 19, 2009 | BenQ FP531 15" LCD Monitor
I can't control the monitor
From what you are displaying, sounds like the monitor is faulty. If you can, try to borrow another monitor for testing.
Nov 30, 2008 | BenQ V773 17" CRT Monitor
FP531 Monitor flashes 'Benq'
sounds like an internal issue with the power board service tech should look at it
May 10, 2008 | BenQ FP531 15" LCD Monitor
Monitor flash
Does display switch on and off with front led remaining on?
Nov 17, 2007 | BenQ FP531 15" LCD Monitor
Computers & Internet Logo
75 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
