Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Beater bar Hi,I have a hoover windtunnel supreme. I am trying to remember how to get the beater bar to work after I used the attachments.
  • shavers3 Oct 03, 2009
    There was no switch on the hood. It is a few years old. It is dark blue in color.
    Scholar:
  • 190 Answers
There may be a shutoff switch, located on the hood, that shuts off the agitator to permit bare floor cleaning. Return the switch to carpet mode.
Posted on Oct 03, 2009
Testimonial: "Thank you for your advice and referral to the manual. It is helpful. I don't have the self propelled version though I assume all else is the same. "
Hoover windtunnel
Hello--How about the Flat belt? That would be my next step...then, if it's still not turning, perhaps the beater/agitator bar's bearings are the culprit...calling for a new beater bar /agitator.
Hope this helps--
Aug 28, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Windtunnel first one used 6 times beater bar stopped working, took apart cleaned and belt was fine. this one had a reset switch for beater bar. had insurance at best buy so returned for a new one. used...
Sorry, you feel like that. I have rentals and 6 windtunnel's (I prefer the bagged ones) and have never had a problem such as you have described. I think Hoover makes a great vacuum.
Sep 14, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover beater bar is loud & vibrating.
brush roller /agitator needs replacement. part price : $25.00 to $ 30.00
May 06, 2010 | Hoover U6630-900 WindTunnel Bagless...
How do I install a hoover windtunnel vacuum cleaner belt. The bagless one,.
First, take it outside or to the basement. This can get messy. Turn the vacuum cleaner upside down. Remove four 1-1/2" self-tapping screws that hold the bottom cover in place (where the beater bar is.) Remove this and you will see where the belts go; one from the beater bar to a grooved wheel and one from a bowed wheel to a metal spindle way in the back. The beater bar will lift right out. Be sure to clean the threads and pet hair while you're at it.
Mar 28, 2010 | Hoover U6630-900 WindTunnel Bagless...
Beater bars won't turn
It is a really simple and cheap fix! All you need to do is replace the belt. You can get a replacement belt here:
Hoover Windtunnel Belts
Jan 10, 2010 | Vacuums
How do I change the belt on the motor?
Hi. This is easily done. Flip the vacuum over, beater bar up. With the machine unplugged, locate the screws or tabs that hold the base plate on, surrounding the beater bar. Remove the plate. The beater bar is held in place by fitting into sockets that then fit into the vacuum frame, so be careful in removing the beater bar. Pay close attention to the sockets, so you can get the bar assembly back in easily. Replace the belt. When you fit it over the motor shaft, you'll have to slip the belt onto the beater bar, and fit the bar into the frame at the same time. Reinstall the plate, and test your work by revolving the beater brush a bit by hand......If you're satisfied, you should be good to go!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Jul 30, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dark marks on carpet after using hoover
these dark marks are burn marks from the beater bar itself. most walmart, kmart, and target shelf vacuums from hoover, dyson, and any cheeper vacuum has a hard bristle system. I've noticed even on the high end hoovers as well that they do the same thing. the best way to save your carpets is to see if there is a replacement beater bar that can be substituted for your vacuum. i dont know what style of beater bar that particular one is but check with your local vacuum repair center to see if they have something with softer brushes you can use insted otherwise i would recommend a new vacuum with softer bristles. usually something that is half as stiff as what is already on yur unit. you culd also try lifting the hight setting as a temporary solution.
Sep 06, 2008 | Hoover U5450-900 Windtunnel Supreme Bagged...
Hoover Beater bar belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40485&thid=744864
Posted by rubyspider on Jul 05, 2008
I need help installing the beater bar belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover U6437-900 / U6439-900 WindTunnel. All you need to do id to remove the bottom plate by removing either the screws, clips or levers and the bottom plate should come right off, and then you can get @ the belt – if not then the top cover will come off and then you can serv it from the top if needed. Then you can lift up the one end of the Hoover brushroll and then slide the new belt on to the pulley side of the brushroll and then use a belt puller or a screwdriver with a hook on the end and then pull the belt onto the motor pulley. Then track the belt in a straight line. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Does not work
No motor? No beater? No nuthin? Let me know and I'll guide you.
Nov 10, 2007 | Hoover U5450-900 Windtunnel Supreme Bagged...
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
170 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
