Question about Microtek ScanMaker 4800 Flatbed Scanner
Cleaning inside of glass scanmaker 4800
The under side of the glass is dirty. How do you open the devlice to clean this part of the device?
  • Anonymous Aug 26, 2008
    Have a Microtek ScanMaker 6000--inside of glass has been dirty (fingerprint smudges) from day one! There are no screws ANYWHERE in sight. Product appears to have snap on frame over the glass. Is it possible to pop the lid without breaking the entire assembly? Oh, the the red lock button on the bottom will not turn to lock the scan assembly either...
    Next problem: M-tek ScMkr 6000 constantly aborts it's scan--produces black or white pages to the tune of a huge squeal-- or totally locks up and the entire pdf document is lost if not previously saved. OS is Windows XP w/SP 2, pdf program is Adobe Pro 6.0. Any suggestions and answers to source of problem?
  • ivstamp May 11, 2010
    Cleaned without any probems !!!
    You need to understand the there are snap grips on the back and sides.
    Remove screws and lift up about 1/4 inch.
    Then put pressure on it to slide toward the front.
    To install, insert in tabs at front, slide toward back and genrly push down to reseat the sanp clips.
    Piece of cake !!
  • 5 Answers
Further to Anonymous's response: I will extend his comments:
"Open the lid, pull it up and off and you will see two screws below the hinges. If you have decided to purchase another scanner already, you are clear to proceed. Take these out, pry the halves apart until you hear a click. Push the upper section toward the control panel and the will come apart like a freshly caught oyster."
There is more to it than removing 2 screws. BEFORE YOU BEGIN, after removing the lit, slide the "LOCK" at the front of the scanner when upside-down. This secures the scanner head from movement related damage.
If you look inside the glass on the right and left walls, you should notice 2 (on each side) clips. You want to carefully wiggle the top so that these come loose. You cannot simply push the top toward the back and have it separate - though the clips look like this would be possible. There are two tabs at the front of the case which prevent this from happening.
No need to remove the front control panel cover, it is not relevant to this process. Also, all the hardware is part of the bottom of the case, so no concerns removing it. Unless you break a clip, then you are in trouble.
Re-assemble in reverse order for these instructions, and voila, clean scanner!
Posted on Jul 23, 2016
What did you use to clean the glass with?
Posted on Jan 13, 2008
OK Just Stupid (G).... Open the lid, pull it up and off and you will see two screws below the hinges. If you have decided to purchase another scanner already, you are clear to proceed. Take these out, pry the halves apart until you hear a click. Push the upper section toward the control panel and the will come apart like a freshly caught oyster.
I would not only clean the inside of the glass, but would get a can of compressed air and blow the heck out of the area below the black thing. This should get most of the dust off of the mirrors (3).
I took mine apart and cleaned them, but, if you had problems opening the case, I definately would not try taking this assembly apart. It'll make you cuss.
Posted on Jan 02, 2008
How do I clean the inside of the glass of the fireplace?
Crumple up newspaper, use it like a rag, scrubbing the glass. Not abrasive enough to scratch the glass but enough to clean soot deposits.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to clean your Fireplace Glass
Gas Fireplace Repair Dirty Glass My Gas Fireplace Repair
How To Clean Your Wood Stove Fireplace Glass
Cleaning glass on woodburner
Mar 02, 2016 | Heating & Cooling
Remove glass door on kitchen aid stove, to clean
I'm wondering if you really need to remove the door to clean it. Just open the door and clean the inside of glass.
Jun 22, 2014 | Computers & Internet
Sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
Feb 28, 2012 | Office Equipment & Supplies
My s400 works with Vista but not Windows 7, I
It will work with win 7 but it is complicated.
Download driver from the Microtek website
extract the files to your drive
locate the setup.exe file where you extracted the files
after the driver is installed reboot the pc
Now for the fun part...
Once PC is fully rebooted plug in Scanner ScanMaker s400
Windows looks for drivers in “windows update” and the “preconfigured driver folder”
Windows cannot find a driver.
Close “Driver Software Installation” window
Open Device Manager
Device manager shows yellow bang next to “USB scanner” under “Other Devices”
Right click on usb scanner
click “update driver software”,
Click on “Browse my computer for driver software”
Click on “let me pick from list of device drivers on my computer”
Click on “Imaging Devices”
Click Next
Under Manufacture there is no Microtek
Click on “Have Disk”
Click on Browse
Locate ScanWizard 5 V6.63 folder
Locate Disk 1
Locate Vista
Locate X86
There is a list of INF files
Choose first inf file, “Mii_x86_004.inf”
Click Open
Click OK
Now under Manufacture two entries are listed, Microtek and Microtek Driver Team,
On the other side there is a list devices s400 is not listed
There is an entry for 4800 Scanner
Select it and click next
An “update Driver Warning” opens select yes
Window now shows successful driver update.
And the scanner is listed as 4800 scanner
Click close
Close device manager
Open Scan wizard program
Scanner works fine.
The scanner will not work nativly with windows scanning.
Nov 11, 2009 | Microtek ScanMaker s400
When I feed pages through the automatic feeder, the copies come out with a streak on them. If I put them directly on the glass it doesn't happen. I have cleaned the platen glass with no result.??
It is a cleaning issue. There is a piece of glass about an inch wide that is next to the platen glass or inside the auto document feeder that is probably dirty depending on your model. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 03, 2009 | Canon imageCLASS D320 Digital Copier
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Remove top glass from scanmaker 8700
Sir,
Please click on this lin http://www.artixscanm1.com/Cleaning_Instructions_Chassis_VI.pdf and download the manual for cleaning the glass for your scanner.
Go to page 2 and follow the instruction step by step.
Have a nice day.
Thanks
Oct 30, 2008 | Microtek ScanMaker 8700 Flatbed Scanner
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
May 27, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Scanmaker 4800 inside of glass needs cleaning. Can this be disassembled ?
Yes you can disassembly this scanner, by unlocking the points of locks (see under the scanner).
May 02, 2008 | Office Equipment & Supplies
Microtek ScanMaker 4800 Flatbed Scanner Logo
661 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Michael
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
