Question about Dryers
Trying to set up electrical outlet for a whirlpool dryer. I matched the red / white / black wires but is the green wire a ground wire and if so where does it go to.
    President:
  • 704 Answers
NEVER, put the green ground wire under the same screw or fastener as the white (neutral) wire! It is not Code and the reason is that if the connection becomes loose or gets burned off, you would have an ungrounded 220V-AC circuit that would use YOU or someone else as the path to clear any ground fault situation.
The correct way is to mount a separate Grounding termination with either the factory green gronding screw (if provided) or by drilling and tapping a hole next to the power terminals, (away from them so as not to make accidential contact) and install a green grounding screw for the cord set's ground wire.
Any other advice is dangerous and can lead to electrocution, injury and death!
Hope you find this Very Helpful and best regards!
Posted on Sep 29, 2009
  • 53 Answers
You can ground the green to the cabinet or double it up with the white wire on the center post.
I am trying to change my miller welder 4 prong plug to qa 3 prong to match my dryer outlet ? which wire goes where ?
On 4 wire outlets the neutral and ground wire were seperate on 3 wire the ground and neutral are combined so hook up the 2 hots (black&red) as before on the 2 outside terminals and combine the green and white together onto the center terminal
Nov 12, 2011 | Whirlpool LER5636P Electric Dryer
I am trying to find the ground wire for this dryer.
On whirlpool (all manufacture) dryers the ground wire is linked to the center terminal with the white wire and attaches to the cabinet grounding all metal on dryer since on panel attaches to the next making the entire cabinet have continuty through the neutral/ground wire.
When connecting 3 wire cord connect the two outside wires to red/black on cord block and center wire to white/center terminal connection on block.
For a 4 wire cord red to red black to black white to white and the green to rear of cabinet/any panel near block
Aug 13, 2011 | Whirlpool WED5100VQ Electric Dryer
We just moved into an older home, the 220 dryer outlet is set up for prongs. I went to a hardware store and bought a Magnum 4-wire cord that matches the outlet. My dryer has a 3 wire cord. I removed the...
The red and black are the "hot" wires... white is the neutral and the green gets hooked to the frame of the dryer...
Here is a tip that gives more detail...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 28, 2010 | Faber Pro Magnum 605989 Kitchen Hood
3 wire Dryer Plug needs changing 4 wire plug because of outlet.
Black to one side of 115
Red to the other
White Ground to the middle
Green to case.
Please rate me if this was helpful
Leo Ponder
imufo2@sbcglobal.net
Aug 01, 2010 | Whirlpool GEW9250 Electric Dryer
The electrical outlet does not match with my dryer cable, so I get a new set of wire from home depot to match the wall outlet. how do I hook it up?
Hello, welcome to Fixya,
If you'll notice the new cord has 2 hot (red & black) a neutral (white) and ground/earth (green) wires. In case you are not sure how to connect I've attached a photo which shows the correct way.
Thanks for visiting "fixya" and good luck. Please take a moment to rate the solution I provided for you here today.
macmarkus :)
May 24, 2010 | Amana NED5500TQ Electric Dryer
Just moved and outlet for dryer is different.
Connect the red, black, and white wires of the new cord to where the red, black, and white wires of the original dryer wires are connected to but disconnect the ground wire (green/yellow wire attached to the cabinet) from where the white wire is connected to and connect it instead to the fourth green/yellow wire of the new cord.
Apr 12, 2010 | Whirlpool LER5636P Electric Dryer
I am trying to convert the 3 prong cord to a 4 prong cord and don't know where to put the grounding terminal from before...it was on the dryer internally.   I got everything hooked up correctly (i...
The following link explains how to correctly install a 220VAC appliance cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Read through the instructions provided and let me know if you have questions. This advice is how to convert from a 3 prong to a 4 prong appliance cord. You simply match the corresponding colors of the wires on the cord you intend to attach to the matching colors at the terminal block on the back of the dryer. If the wires are not color coded at the terminal block, the outer two wires (left and right) are the HOT leads, the center wire is the Neutral. Make sure the neutral and ground wires remain independent of each other in a 4 wire configuration. The green wire should be terminated on a ground lug on the equipment cabinet while the neutral is terminated at the terminal block.
Let me know if you require further assistance. I hope this help you.
Feb 09, 2010 | Whirlpool WED5500S Electric Dryer
I have a 3 wire dryer and need to convertto a 4
The following link explains how to correctly install a 220VAC appliance cord:
Match the corresponding colors at the terminal block, making sure the Neutral (White) and Ground (Green or Bare Copper) wires are NOT terminated together.
If you have any questions, please post back and let me know. I hope this helps you.
Feb 03, 2010 | Kenmore 62602 Electric Dryer
Changing electrical Cord from a 3 prong to a 4 prong. I need a wiring diagram
black to black lug white to white lug red to red lug green to ground(any bolt that is attached to body of dryer)
Dec 20, 2009 | Whirlpool Dryers
Whirlpool LE5795XPNO 3-wire to 4-wire
The following link explains how to convert your dryer from 3-wire to 4-wire:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you have questions, or require further assistance, please let me know. I hope this helps you.
Jan 11, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
