Question about Konica Minolta DiMAGE E50 Digital Camera
When I switch on my Konica Minolta E50 camera, "Error 2" appears and the lens does not come out. How can I fix it?
    Problem Solver:
  • 10 Answers
Solution for Error 2 on Minolta Dimage E50 is not very ease, anyway, the problem is involving the socket lens control flat. To proceed: remove front screws of camera, then check on left bottom close the lens if the flat socket ir really inserted on his plug. The socket is located under a flat cable coming from the back of camera, it is large about 1,5 cm. To test it you can remove temporally the adesive shield orange pay attention of not damage the flat cable. Otherwise if camera drop down the flat can be damaged and you need to replace the camera lenses.
Posted on Nov 08, 2009
Minolta Dimage S414 does not turn on, displays err message then shuts off? No error code, just err. Been in storage four years, probably stuck lens or something?
Go to this website and try the fixes listed....one of them may "kickstart" your camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 29, 2011 | Konica Minolta DiMAGE S414 Digital Camera
My cam show format error after format by pc plz help urgent
Use the camera's own format function. You will find this somewhere in the setup menus.
Oct 30, 2010 | Konica Minolta DiMAGE E50 Digital Camera
Darkened image
same for you, please red this: "My camera is 2 years old. 6 months ago horizontal lines began appearing in all pictures" The problem is not the sensor as the first solution has been posted, the real problem is connected with the flat cable inside lenses that is broken. You cannot replace it, you can raplace intere zoom. The problem is frequently on this type of camera and direct connected with camera frequent use. The fixed and automatic diaphragm do not work bacause broken flet is broken and the sensor is receiving too mach light. Take the camera, switch it on then light with a flashlight the lens, you see a diaphragm movement or hear a click on the lens, if not the flat wire is broken (means microcut inside flat invisible without a magnifying glass). Most time same problem is present with no image on the screen because diaphragm is completelly closed.
Oct 23, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Konica Minolta Dimage E50 suddenly over expose. Indoor at night, the picture looks almost normal. Daytime the wall will be too white. Outdoor the picture is white out.
Hi!
The shutter cable inside the lens has broken - a common problem with the E50. The cable moves as the lens zoom so it brakes at some point and then camera isn't able to control the shutter - control the amount of light taken. If you look closely at the over exposed pictures, you will notice horizontal lines accross them.
The shutter or whole lens unit has to be changed. It is quite expensive, I believe it's not worth it. You can contact Sony / Konica - Minolta service center.
I work in a Sony / Konica - Minolta service center and have repaired a lot of these.
Hope this helps!
Tom
Oct 05, 2009 | Cameras
Sustem Error S0042
Todd, What you can do is to powerit on and try to pull the lens out manually. Do not use too much strength or rotate. But try it a few times and the lens casing may stop touching the camera body. Once the lens comes out fully then the camera will boot up and work.
Sep 12, 2009 | Konica Minolta DiMAGE G600 Digital Camera
Cam cannot mak any pictures. ''Error 2''
I have already answer to this problem. To try on solve it you need to remove the metal front cover and check if the socket of the large flat coming fron the back of camera is complete inserted on his shell, or if you damage the cable because the camera drop down
Apr 11, 2009 | Konica Minolta DiMAGE E50 Digital Camera
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Dec 27, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Konica minolta dimage z6 problem
Sony handle repairs to Konica Minolta gear (I think) good luck.
Feb 10, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Hoizontal lines in images
The problem is faulty CCD sensor ( this device converts light into image ) so faulty sensor means either poor quality pics or no pics at all. Have sensor replaced and camera will work fine.
Sep 11, 2007 | Konica Minolta DiMAGE E50 Digital Camera
Minolta G530 System error MF00C
Lens motor stalled - a repair is not likely Check out the Konica web site
Aug 03, 2007 | Konica Minolta DiMAGE G530 Digital Camera
Konica Minolta DiMAGE E50 Digital Camera Logo
300 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
