Question about Home
Small streams of H2O down interior sides of commode bowl. Have replaced flapper and color tested for leakage,Nada, replaced ballcock fill assembly with Fluidmaster unit and still getting very small amount of water still coming down interior sides
  • 297 Answers
This is still the flapper.each toilet has a flapper designed to fit each toilet.your may not have the right flapper for the toilet you have.not all flappers weights are the same.youmay need to add some weight to the flapper or replace it with one that is designed for that model toilet.good luck with your project
Posted on Sep 29, 2009
Eljer Windsor One Piece Toilet help - leaks water into bowl
I would go back with the ballcock kind. However, the flapper will need to be replaced. It is not seating properly. The fluid master is a revised version and a bit more efficient. It should work well also. They both work off buoyancy and shuts off water the same way.
Feb 18, 2013 | Home
Tip
HOW TO CHANGE A BALLCOCK ON COMMODE
HOW TO REPLACE A BALLCOCK ON A WATER CLOSET, COMMODE: FIRST SHUT WATER OFF TO COMMODE. THER WILL BE A WATER SHUTOFF VALVE BETWEEN THE FLOOR AND THE COMMODE ON THE WATER LINE TO YOUR BALLCOCK, TURN WATER OFF, FLUSH COMODE SO YOU CAN CLEAR MOST ALL OF THE WATER OUT OF IT. THEN UNCREW THE NUT FOR THE WATER SUPPLY, THEN UNSREW THE NUT FOR THE BALLCOCK ITSELF, OPEN THE TOP OF THE COMMODE, YOU WILL SEE A FLAPPER ON THE BALLCOCK, REMOVE IT, THEN TAKE THE BALLCOCK OUT, SOME HAVE A ROD AND FLOAT SOME DO NOT, EITHER WAY IF IT DOES WHEN YOU PUT THE BALLCOCK BACK IN THE SAME WAY THE OLD ONE CAME OUT MAKE SURE YOU HAVE THE GASKET ON WHEN YOU STICK THE END OF THE BALLCOCK BACK, TIGHTEN THE NUT, THEN MAKE SURE YOUR WASHER IS IN THE NUT ON THE WATER LINE AND RE CIONNECT WATER LINE, YOU CAN ADUST FLOAT VALVE BY BENDING THE ROD DOWN TO THE AMOUNT OF WATER YOU WILL WANT CONNECT FLAPPER BACK, TO THE NEW BALLCOCK, IF THE BALLCOCK DOES NOT HAVE A FLOAT, YOU CAN ADJUST PER INSTRUCTION, SO AFTER ALL THIS IS DONE AND TUBE IS CONNECTED FROM BALLCOCK TO THE TOP OF IT WITH CLIP, TO DIRECT YOUR FILL WATER, TURN YOUR WATER ON AND ADJUST SOME MORE IF NEED BE, UNTILL YOUR CORRECT AMOUNT OF WATER IS LIKE YOU WANT IT...THIS IS REALLY EASY COMPARED TO PAYING A PLUMBER FOR THIS JOB, AND IT HAS TO BE DONE QUITE OFTEN, LARRY VEAL MASTER PLUMBER TEXAS
on Apr 24, 2010 | Plumbing
Very slow refill on tank. How to adjust?
Hi carlson33 19...
I would say your fill valve (ballcock) has trash in it or needs to be replaced because of age.
If you replace it you can get the "ballcock" from just about any hardware supply,Home Depot,Lowes...etc.. and I would recommend the replacement of the "flapper valve" also at the same time.
All the instructions for adjusting are on the package of the ballcock...
This should solve your problem.
Free Answer...Please rate me
Apr 21, 2011 | Jacuzzi Bath Era BK37 959 White toilet...
Not flushing, bowl will not fill up with water
Hi rjhfp
Check inside of the tank to make sure the connector from the handle of the flusher to the "flapper valve" is connected, to do this you have to remove the tank lid.
If it is connected then you have a different problem.
Sounds like you have trash in the valve inside of the "ballcock assembly"
The ballcock assembly is the part that lets the water into the tank, and the "flapper valve" is the part that allows the water to flush into the bowl...
Replace you ballcock assembly and it will solve your problems.
Apr 16, 2011 | Pegasus Technologies Two-Piece Round...
Water flow does not stop
you probably have a bad flapper valve. The flapper valve sits in the bottom of the tank and allows the water to flow into the bowl when you flush. Turn off water supply to the commode and remove the tank lid. Feel the flapper valve, ensuring it is seated fully on the opening and is not damaged. If any rubber comes off on your hand or it feels slimy then you need to replace it. Remove flapper and take it to your local hardware store to match up with what they have on the shelf - you may need to cut some parts off of the replacement valve as they are designed to fit several different commodes. It is also possible that your float is stuck and you may need to replace the float and fill assembly - if this is so, the new assembly will come with detailed instructions to replace.
Hope this helps!!
Nov 29, 2010 | Toto Home
Toilet runs water in the bowl, replaced the flapper and ballcock, it still runs in bowl.
hi ur chian could be to short or u have to ajust the flue screw at the end of the ballcock arm wher the water flues into the bowl hope it helps u
Nov 01, 2010 | Eljer Toilet Onepiece Canterbury ...
Water keeps dripping in the tank, but the tank doe...
This description is a little vague, but I will do my best to help. The first question I would ask is. Is this water going down into the bowl? This can be checked by adding a couple drops of food coloring to the water in the tank and waiting a little while before looking for colored water in bowl. If there is colored water in bowl than the most common problem would be a faulty flapper or flush gasket. If no colored water shows up than the ballcock valve may need to be adjusted or replaced. I hope this helps.
May 20, 2010 | Home
VitrA #5055 toilet why will it not stop running
the flapper is not closing all the way in the tank. if, when the handle is at rest, the flapper chain is too taut, the flapper is not closing all the way. so loosen the chain. if there is slack, the flapper is not making a good seal and is letting water through. or if in the tank the water is going over the standing up overflow tube, you need to adjust the float. if you have the ball float, lift it up slowly and see if the water stops running. if not, replace the ballcock (valve where the float is attached. if it does stop, unscrew the ball a little or bend the ball arm down a bit until the water stops short of the overflow. if you have the shuttle float, do the same test. if the water does shut off, adjust the shuttle accordingly.
Nov 12, 2009 | VitrA Aria Toilet with Round Bowl /...
Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Dec 21, 2008 | Home
Home Logo
240 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
