Question about Sony Xplod XM-1652Z Car Audio Amplifier
Amp keeps quiting on me
Why does my amp quit when i turn it up loud? all my wiring is right. i think its cuz my speakers ask for to much watts ther i have two 600 watt speakers
    Sergeant:
    Champion:
  • 362 Answers
Your wiring is right but did you use large enough wire to hook it up. its either not enough amps to the unit or the ground isnt making good enough contact.
Posted on Dec 19, 2007
Amp turns off.
your drawing/pulling too many amps. Is it a mono(one speaker), two way(two speakers/can be briged to one), or a four way(four speakers/can be brigrd to two). don't put too many speaker to that one amp if it's only a mono, or a two way.
Sep 24, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Speaker or amp?
your running too low impedence, and yes its cuz of your sub wiring. How to wire it depends if its 2ohm dual voice coil, or 4ohm dual voice coil, so i'll explain both. O.K. first of all i hope its 4 ohm so you can get max power from your sub. If it is 4 ohm dual voice coil connect + to +, and - to - on your speaker, then to connect it to your amp, splice a wire into the wire running from + to + and connect it to your amp's + terminal. Do the same with your - wire. If its a 2 ohm dual voice coil, connect the + from one set of terminals on the speaker, to the - on the other terminal. Then to connect it to the amp, plug a wire from the open + terminal on the speaker and connect it to the + plug on the amp, and do, connect the empty - to the - on the amp. Good luck and if you have any questions don't hesitate to ask...
Sep 20, 2009 | Car Audio & Video
My 2000 watt nitro amp just stopped working need help
Think about anything out of the ordinary that may have happened the day (or day before) it quit.
  • Was work done to your system?
  • Did someone mess with your system?
  • Smell anything odd?
  • Especially loud?
  • Did it quit mid-song or did it work yesterday and not today?
Assuming nothing special, here are some diagnostics you can perform. At the very least, they will help tell you what the problem isn't, First....
Eliminate power supply problems.
Use a meter to make sure you have power to your amps +12v terminal. A meter is preferred over a test light to confirm a full +12 volts.
Make sure the ground terminal is grounded. A meter with a continuity test option is best for this.
If either of these fail, trace the wires to find the fault. Large amps like yours normally have dedicated power cables. These cables usually have an additional in line fuse close to the battery. Check it.
If they pass, double check the amp fuse.
Pull the wire (usually blue) from the 'remote' terminal on the amp.
Then try jumping the +12v line to the remote terminal.
If it still doesn't power up, check for signal shorts.
Turn the gains down low.
Pull the input lines and try the +12v to remote jump again.
Next pull the speaker wires.
Your amp should now have only two wires and a jumper attached to it. Try the same jump.
If it still fails, the problem is in the amp itself and (I'm sorry to say) leaning toward the serious.
Hope this helped
Mike.
Jul 09, 2008 | Nitro BMW-486 Car Audio Amplifier
SUBS
Hi , you need to replace with thick wire , if possible attache fuse or circuit trip overload protection you may ask to thew radio store .
May 07, 2008 | Polk Audio EX12 Car Speaker
Amp cuts off...
Are the woofers single or dual voice coil?
How many ohms per coil?
If they are dual voice coil, are the coils for each speaker wired in series or parallel?
Are the speakers connected directly to the amp or are the speaker in series (one wire from each speaker connected to the amp?
Have you checked the DC voltage at the amp when you're playing it at high volume (where it cuts off)?
Dec 22, 2007 | Kicker ZX1500.1 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
600 watt 4 channel bridgeable mosfet power supply jensen amp
Swap the wires from one speaker to the other to see if it is the speaker or the Amp/wires.
Oct 23, 2007 | Jensen A600HLX Car Audio Amplifier
Sony Xplod 1000 watt car amp quit working.
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
Feb 03, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Keeps swirching to protect mode
First thing to do is disconnect all of the speaker wires on the amp. Turn on the amp, if it is still turning on and off then there is a definant problem in the amp circuitry. If you have no solid state service skills, I highly advise you to take the amp into a repair shop. If it stops turning on and off turn off the amp and try and connect up one speaker at a time untill the amp starts to mess up. you then take that speaker and have it checked out and inspect the wireing for pinchs or shorts.
Oct 03, 2006 | JBL GTO 301.1 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
81 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
