Question about Olympia Sport & Outdoor - Others
How to repair a popup camper cable bonair lextra 1977
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Posted on Aug 02, 2010
Owners manual for 1997 flagstaf popup camper
You will have to contact Flagstaff, but you also need the actual model number of your camper. You can also google a manual for a 97 Flagstaff model # _______
Sep 13, 2014 | RVs
Where is the ignitor for the furnace in a 1998 flagstaff popup camper
This is the car and truck section. You may want to repost this in the RV section, or contact the company that built the camper.
Sep 26, 2012 | Cars & Trucks
Need a shifter cable for a 1977 dodge winnebago brave motorhome
Usually the shifter is on the dash instead of the column so the RV companies used their own design.
I would check with the RV clubs and research the internet for salvage yards for RVs and campers. Good Sam is one that comes to mind.
You may also find something that would work at a boat dealer.
Aug 28, 2012 | Cars & Trucks
I need the threded rod assembly that cranks up the hard top on my coleman popup camper 1994 i think
IF YOU HAV THE OLD 1 . CHECK AROUND TO YOUR LOCAL CAMPER , OR MACHINE SHOP OR WELDING SHOP, IT MIGHT BE REPAIRABLE.. IF NOT CHECK THE WEB FOR CAMPER CLUBS OR FORUMS .. JAY
Jul 23, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Was given a roof top ac for a popup camper need help
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
Sport & Outdoor - Others Logo
415 people viewed this question
Top Olympia Sport & Outdoor - Others Experts
Are you an Olympia Sport and Outdoor - Other Expert? Answer questions, earn points and help others
