Question about Kodak EASYSHARE Z1485 IS Digital Camera
Why does my camera get hot when in use? - Kodak EASYSHARE Z1485 IS Digital Camera
    Brigadier General:
  • 11,967 Answers
It's normal.
Posted on Oct 03, 2009
  • 101 Answers
If your camera is hot too touch, call 1.800.235.6325. Kodak will replace it for free.
Posted on Sep 29, 2009
How to put on a camera
If the camera is designed for an external flash then it will have something called a "hot shoe"
Google "hot shoe" and switch ti images to see what a hot shoe looks like.
Aug 13, 2014 | Cameras
Auto flash does not pop up on Canon7D
This usually means the camera thinks there is something connected to the hot shoe, but there is nothing connected to the hot shoe. Likely one of the micro switches under the rails of the hot shoe is stuck, or you need to tighten the hot shoe. Here is a nice guide to fix this:
Jan 05, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
Test button- fire, but when attached to hot-shoe (camera or trigger) doesn't fire. Why?
Check the hot shoe contacts and make sure they're clean. If that doesn't help, place the flash on your camera, turn both on and reset the camera to factory default through the menu settings. Also make sure the hot shoe on the flash and the camera isn't damaged. Have you tried the flash on another camera?
Aug 09, 2013 | Canon Speedlite 430EX TTL Flash
Camera turns hot after putting batteries
If your camera is getting hot when you turn it on, then YOU HAVE A SHORT CIRCUIT in your camera electronic component(s) that causing the camera to become hot (rather unusual condition if you can feel it heating up!...): if it is just over 12 months, try to get it repaired under warranty... you can only ask!
Hope it clarifies the situation.
Jan 24, 2010 | Kodak EasyShare C613 Digital Camera
Hot shoe
If the flash is not sitting securely on the hot shoe when attached to the camera you may want to send the camera body to Olympus repair center for service. Their telephone number is 800-622-6372 option 2 and then option 3 to discuss the repair process and pricing if needed.
Dec 29, 2008 | Olympus EVOLT E-500 Digital Camera
Camera gets hot!!!
you might be using the wrong batteries. Usually batteries shouldn't get hot unless you are charging it.
Dec 18, 2008 | Olympus Stylus 600 Digital Camera
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
A310 - Batteries Overheating - Will Not Power On
At a guess incorrect battery type. These should be Ni-Cad or Ni-Ma rechargeables Alkaline batteries do not have to power and will over heat. Check your manual
Jul 05, 2007 | Canon PowerShot A310 Digital Camera
Flash cable
The FL-CB05 Hot-shoe to Hot-shoe flash cable is approximately 3 feet (1 meter).
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Kodak EASYSHARE Z1485 IS Digital Camera Logo
55 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
