Question about HP Asus Motherboard P4SD-LA Socket 478 DQ182-69002 5187-6671
My problem is that since re configuring my computer including a new motherboard (hp p4sd), and reinstalling winxp os, I no longer have the standby or hibernate option available when shutting down. how do I get it back?
  • 52 Answers
Check your power settings in the bios menu.
Posted on Sep 29, 2009
Windows 7 Sound Issues
try this always worked for me https://www.drivereasy.com/
Feb 17, 2018 | HP Nodus3 Motherboard Asus A8m2n-la 45...
ASUS P4SD i865G Socket 478 mATX Motherboard
if i was you i would atleast get windows xp manyour board is more new then your win 2000 but go online you can find them there just type in google your board type
Mar 30, 2010 | HP Asus Motherboard P4SD-LA Socket 478...
Cannot install winxp on asus p5gc-mx/1333
probably ur ram is faulty..replace with a standby n see..
also check for defective capacitors on the main/mother board..
reinstall os..
dis also do happen when ur cd/dvd rom drive is down or the cd frm where u r installing is corrupted..
the above often take place with some error message(s)/blue screen..
but if there's no such displaying, esp if hangs/stops/power off during installation, it may b caused by the main/mother board or even the battery..
..contact ur system admin/vendor....
Oct 29, 2009 | ASUS P5GC-MX/1333 Motherboard
Ethernet driver needed
The beauty of Dell is you can use the service tag to find exact configurations. Since I didn't have that I did find 2400 series drivers at http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_CEL_2400&os=WW1&osl=en&catid=&impid=
This may give you the items you need, Dload to a jump drive and then move to the PC and allow PC to extract them then follow the add hardware wizard or update driver from hardware listing. The drivers may also include their own setup file.
Sep 19, 2009 | IBM (03R0329) Motherboard
Replacement for INTEL Desktop board D865GLC
I've found an Asus P4SD i865GV online:
http://www.geeks.com/details.asp?invtid=ASUS-P4SD-NOAGP-R&cat=MBB
It seems to have the same CPU socket, FSB and RAM types, and the chipset is almost the same model. I'd say this would work.
If you can't get that, just make sure to get a motherboard with the following qualities:
Front side bus (FSB): 800, 533, and 400 MHz
RAM type: Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
CPU socket: 478
Aug 07, 2009 | Intel Desktop Board D845BGL Motherboard
P4sd socket 478 motherboard is not booting up at all !!!
1st check if the voltage from the plug has correct groung , neutral phase set .then
try a new smps , with minimum 400W output.
before connecting the same.
please remove all the parts out of the cabinet please connect only motherboard and smps and check its getting switched on , if not then your board is burnt you will have to replace it , if there is power indication then connect the RAM and check , if its also fine then connect the rest and try.
all this u have tried and no use , please post me a msg with full detail of your PC configuration , I can try a resolution
dil.
Aug 02, 2009 | HP Asus Motherboard P4SD-LA Socket 478...
Unable to get back from standby.
In your problem there is no errors in the hardware, You may/should reformat and reinstall the windows to correct all the errors.
note: reformatting and installation can delete your files so back up it b4 proceeding.
Jan 22, 2008 | Intel D101GGC Motherboard
HP Asus Motherboard P4SD-LA Socket 478 DQ182-69002 5187-6671 Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
