Question about Motorola Mobility i580 Cellular Phone
The phone never loads and a white screen appears
The phone never loads, a blank white screen appears and lasts until battery dies. when i put it back on the charger a white screen flashes on and off repeatedly
    Problem Solver:
  • 15 Answers
Remove the battery from the phone for 10 seconds then re-insert the battery and battery cover and power the phone back on. If the phone is still having problems and you have not had it for more than a year brand new from your phone carrier then it would be covered under a 1 year manufacturer warranty for phone hardware and software malfunction. If the phone has been exposed to extreme moisture or water then the warranty would not cover this problem and if this were the case then there would be a bright red or pink sticker in the phone or on the battery when you remove the battery from the phone. It sounds as if your phone would have to be sent in for repair and to have that done, just take the phone to your wireless carrier and ask them what your options are for repair or replacement.
Posted on Sep 29, 2009
I let my phone battery die yesterday and now when i try to charge it it says that the charger is attached; but when i try to charge it and turn it on it only goes to the main motorola screen with the...
yes of course, you need a new battery.
when you get this battery, also buy a universal charger.
do not insert the battery into the phone until you charge it for 3 hours with the universal charger.
after that the phone will work very fibenluis_14.jpgne.
Jan 27, 2011 | Motorola Mobility Clutch i465 Cell Phone
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
White screen and keypad lights blink
tke out the battery then get an eraser just rub the battery connector sideways....be careful not to dislocate the connector.....and put the battery back-in...u're phone work after this...just email me rosleycatarata@yahoo.com if it works.....
Sep 03, 2009 | Palm Treo 680 Smartphone
Blank screen on Nokia 6085
Frist U Change LCD Second Change Display Strip Third Change LCD IC  In Last Flash Phone.
Apr 09, 2009 | Nokia 6085 Cellular Phone
Blank or White screen on new Motorola Krzr k1 cell phone
Take the phone to a mobile service center and have the flexcable replaced on the phone.
Dec 04, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
Sep 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
If the phone still works, check to see if the left side of the hinge (when the phone is open and facing you) is loose. If you can wiggle the top 1/2 of the phone, the hinge is damaged, therefore damaging the flex cable that runs through it. If that is the case, replace the hinge assembly and the flex and you're good.
The K1 is no joke to take apart. Flex replacement requires full disassembly. I would recommend checking out www.wirelessunlimitedinc.com, or www.myspace.com/wirelessunlimited to have it done professionally, less than Motorola will charge you.
Or give it a shot if you want, you need a T5 Torx and lots of patience and care.
Jul 31, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola Krazr Cellphone : problem screen
Yeah my friend had this very same problem with her phone i told her to just
1. turn on the phone leave it open and let the battery die
2. after it dies take out the battery and hook the phone up to the
charger
3. put the battery back in and turn the phone back on
then it should work.... well it worked for her and i hope it works for you too
Dec 19, 2007 | Motorola Mobility RAZR V3x Cellular Phone
My cell keeps shutting down when i try to turn it on
i have a razor vx3 that was doing this every time i would get a phone call. I returned it for a new phone thought att.
Dec 03, 2007 | Motorola Mobility RAZR V3x Cellular Phone
My sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Oct 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Mobility i580 Cellular Phone Logo
293 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
