Question about HP Compaq Presario SR1010V (568656) PC Desktop
Compaq presario sr1010v power light blinking - HP Compaq Presario SR1010V (568656) PC Desktop
  • 788 Answers
Try disconnecting the A/C source.
Allow unit to set for 5 minutes.
Re-install power and restart uint.
If that does not work, Disconnect power and remover supply connections at the motherboard.
Allow to set for afew minutes, and re-connect.
Sometime, removing the connections at the motherboard, allows the supply to reset.
You should have a 4 pin video connection and a 24 pin main board connection.
Note. Make sure your power is disconnected before attempting this service.
Posted on Oct 01, 2009
  • 63 Answers
This could be several things from the red power switch on teh back of thecomputer in teh wrong position ( 230 v vs 120 v) to a faulty switch.
If you have access to teh internect via another computer go to the following address and down load the trouble shooting directions from HP
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=ie&docname=bph06788&product=89327#N1010
Posted on Oct 04, 2009
3 Suggested Answers
  • 103 Answers
SOURCE: COMPAQ PRESARIO SR1010V!!!
Ouch! The answer to your question is yes. The hard drive inside the tower has all your information on it (regardless of the condition of the rest of the PC) and can be transferred to another computer by making it a 'slave' drive. Then the computer's main HD (also called 'master' hard drive) can usually read from it. Rest assured, your data is still there.
If this helps, please rate this as "FixYa".
Posted on Feb 04, 2008
melnavz
  • 1226 Answers
If the hard drive is is not damage maybe you can save all important files on it.
Please do the step by step troubleshooting of your laptop.
REmove the following:
1. Memory
2. hard drive
3. processor:
4. Battery
try this;
1. Fix some other connection inside the laptop
2. Insert AC plug then start the system.
3. shutdown the system
4. Insert the processor
5. swittch on the laptop.
If beeping; continue
step 3;
6 insert the memory.
7. start the system
8. If display, connect the harddrive.
in step 5: if not beeping:
Either board or processor is dead.
IN step 8.
9. start the system.
10. if the hard drive is detected, and cannot continue booting
i recommend you to reinstall the windows.
Please notify me if problems arises. i will give you further instruction, melnavz.
Compaq presario won't boot caps lock blinking power button on
hi
maybe you have change the keyboard , it is failure
Sep 05, 2012 | Compaq Presario Notebook
Good day.. my compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only..thanks
Hello good day,sir
My compaq presario cq40..is powering on but blank on the screen and caps lock and num lock blingking only.I try ready so many time but everything are not meaning for me that's why i need your help,sir.please,give me some advice for power back.
Thank sir.
Feb 18, 2011 | HP Compaq 6735s Notebook
I have Compaq Presario SR1010V. When I turn it on, no display.
Your Computer system is not POSTing see my guides below they will help you get it going again.
My published guides are entitled;
How to Remove the Side Panels of My Computer Chassis!!!
next up
How do I reset my BIOS/CMOS to defaults?
For the grand finale
My Computer is not turning on!!! Is it dead!!! No POST!!!
Happy Testing!!!
damnor01
Jan 29, 2011 | HP Compaq Presario SR1010V (568656) PC...
I have a Compaq Presario SR2010NX that will not boot. When I plug in the power cable, a green light blinks at the back of the tower on the power supply. I was given the desktop in mint condition, which...
your power supply is bad. the blinking light means there is a failed component in the power supply. replace the power supply and you will be good to go. around 60 dollars at any computer place. please rate me thank you.
Jan 04, 2011 | HP Compaq Presario SR2010NX PC Desktop
Hi have sr1200nx blinking green light no power took side off checked connections still not working any advice thks
Usually led flashes are a code that gives the problem.
Two sites that may help are;
http://www.user-guides.co.uk/download/compaq/compaqpresario/compaq-presario-sr1230nx-disk-download.html
Go to the end of this page to see code definitions.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bph07107
for more generic data
Oct 26, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Blinking power and charge lights
The power plug on the laptop seems to malfunction. Or the Jack is loose.
Oct 12, 2009 | Compaq Presario Notebook
Amber light blinking Compaq Presario Notebook
Pull out the battery and replace it again. Then power it on again. If the problem persists, you will need to have the motherboard, processor and RAM checked by appropriate technical personnel. Any of these could be responsible.
Sep 17, 2009 | Compaq Presario sr1111nx 2.53GHz Celeron...
1. Memory
2. hard drive
3. processor:
4. Battery
try this;
step 3;
7. start the system
IN step 8.
Feb 04, 2008 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
System will not power up
Here is a Compaq document will walk you thorough a fairly lengthy procedure that should solve your problem. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=431080&query=presario%20sr1220&dest_page=product#N561 Let us know how this turns out or if you need any additional assistance.
Jan 02, 2007 | HP Compaq Presario SR1220NX (PJ517AAR) PC...
HP Compaq Presario SR1010V (568656) PC Desktop Logo
172 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
