Question about Kenmore Elite HE4 Electric Dryer
CAN U PLEASE TELL ME THE AGE OF THIS DRYER PLEASE 110 C60952990 SER # MJ4701614 THANX LEE
  • 84 Answers
Brand: Whirlpool
Type: Dryer
Country: USA
Model: 110C60952990
Serial: MJ4701614 This product appears to have been manufactured the week of November 22, 1999.
Posted on Dec 10, 2012
  • 5,911 Answers
The manufacture date of the appliance is determined by the serial number. The following link explains how to determine the date on a Whirlpool manufactured appliance:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
According to the instructions, your dryer was manufactured in the 47th week of 1999, which would be in the month of November.
If you have questions, please let me know. I hope this helps you.
NOTE: Your Kenmore is manufactured by Whirlpool. The "110" prefix in the model number is the Whirlpool manufacturer code.
Posted on Sep 30, 2009
Testimonial: "THANX VERY MUCH YOU SAVED ME FROM BEING RIPPED OFF . WAS TOLD THE MACHINE WAS 5 YRS OLD ! THANX AGAIN LEE"
I am trying to determine the age of my Kenmore gas dryer- Series 80 model 11070802990 ser MK 1715724
There is a web site, appliance411.com, which helps to identify the age of major appliances. I have gone there and looked up your dryer, it appears to have been manufactured in April of 2000.
Aug 02, 2013 | Dryers
My matag problem.......sounds like a small gun going off. It comes from the freezer...about once a day. Thanx......David McCarthy
this is a problem with the way the cap tube has been installed . and it may be under factory warranty . ck the age of unit . you can also call maytag with model and ser # . the only to correct is to change the line to comp or compressor itself .. mm
Sep 01, 2010 | Maytag MTB2156GES Top Freezer Refrigerator
I have a kenmore elite dryer mod c60952990 / ser mk0501696. it keeps shutting off after only about ten min. if you set the timer to 90min it still turns off after about ten min. same if you use the ''auto...
It sounds like it might be overheating. Could your vent be clogged up? When you start the dryer go outside to the vent to see if there is a real good flow of air coming out. If not, the hose or the insides of the dryer are clogged, or the hose is kinked. Sorry, I can't come up with anything else that would be an easy fix. Best of luck.
Jul 26, 2010 | Kenmore Dryers
No heat on model # 110.C60952990
replace the fuse in bach of dryer it is under the cover it is a white plastic looking thing has one screw holding it on two wires going into each end of it take wires off and quarter inch screw you can but at home depot
Mar 10, 2010 | Kenmore Dryers
The 3 prong plug that plugs into the wall has three wires at the end and need to know where do i hook those up too. its a kenmore dryer model #110-64852-400. the ser # is mr2206786
The following link explains how to correctly install a 220 VAC applaince cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
There is a difference in how the 3-wire and 4-wire configurations are terminated. Follow the wire color codes under the 3-wire configuration.
If you have any questions, please post back and let me know. I hope this helps you.
Jan 14, 2010 | Dryers
I have a Kenmore Elite dryer Model:110.C60952990 almost no heat.
Before assuming you may have a component failure, do a little routine inspection of the dryer and exhaust vent ducting.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be because the exhaust ventilation ducting is clogged. If you can't remember the last time the exhaust vent was cleaned, or if it has never been done, this can contribute to dryer performance problems. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat, causing poor drying results and eventual failure. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted with the moisture from your clothing. If the exhaust vent is kinked or has excessive bends that create choke points, lint will accumulate in these points. Once the lint starts to accumulate, the moisture from your clothes starts to collect in it, and more lint get trapped. This eventually creates a clog. The Rule of Thumb: The SHORTER and STRAIGHTER the exhaust ventilation ducting, the BETTER.
A simple test to determine if you have a clog somewhere is to remove the dryer hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees). If the air flow is normal and the clothes dry as they should, then you need to inspect the ducting thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
If your exhaust vent runs to an attic, this is a poor design that gravity will always win because of the resistance the blower fan meets trying to push the exhaust up the wall. The lint will eventually collect in the ducting going up the wall and have to cleaned out from time to time.
Also, make sure you don't crush the dryer hose behind the dryer when you push it up against the wall. You should always leave plenty of space behind a dryer to prevent this from happening.
Rodents and birds are anotehr cause of dryer problems. If they have access to the outside exhaust vents, birds will build nests in them and mice love a warm place with plenty of bedding material (lint makes a nice nest). Make sure the exhaust vent is at least a foot from the ground and use a louver type cover to keep pests outside. Do not use a screen. It can resist air flow and clog.
In addition, you should be using semi-rigid metal type ducting that resists kinking, crushing and rodent infestation.
If the air flow is weak, then you need to inspect the dryer INTERIOR to see if the air blower is working properly and is not clogged. It is important to keep a dryer checked routinely. Failue to do so can lead to component failures and is a potential fire hazard.
Sep 18, 2009 | Kenmore Elite HE4 Electric Dryer
I want to know the age of my dryer model #de485rw ser #7339818
I want to know my dryers age model #fer341ac0
Apr 21, 2008 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
335 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
