What is the capacity of r134 in my chevy 3/4 ton
What is the capacity of r134, and compressor oil, in my 1996, chevy, 3/4 ton, 4x4, 5.7 litter, truck?
    President:
  • 3,433 Answers
All that info should be on a label either on the compressor or on top of the radiator fan gaurd. Good Luck ....Ned
Posted on Oct 03, 2009
How much freon does a 2002 Chevy Tahoe take with a 4.8 v8.The system has already been evacuated and is ready to be recharged.
Should have a sticker on the radiator core support that shows how much it takes . But if your's is missing here
Refrigerant System Capacities
Application
Specification
Metric
English
PAG Oil GM P/N 12378526 for United States
PAG Oil GM P/N 88900060 for Canada
Accumulator Replacement
-ml*
- oz*
* Add 60 ml (2 oz.) of PAG oil, plus the equal amount of oil drained from the accumulator.
Compressor Replacement
60 ml
2 oz
Condenser Replacement
30 ml
1 oz
The Delphi replacement compressor is precharged without PAG oil.
The Denso replacement compressor is precharged with 237 ml (8.0 oz) of PAG oil.
Evaporator Replacement
90 ml
3 oz
Evaporator, Rear Replacement
90 ml
3 oz
If more than the specified amount of PAG oil was drained from a component, add the equal amount of oil drained.
Total System PAG Oil Capacity
240 ml
8 oz
Total System PAG Oil Capacity with Rear A/C
330 ml
11 oz
R-134a
Refrigerant Charge
0.8 kg
1.8 lb
Refrigerant Charge Utility with Front and Rear A/C
1.2 kg
2.7 lb
Refrigerant Charge Suburban with Front and Rear A/C
1.4 kg
3.0 lb
Mar 15, 2017 | 2002 Chevrolet Tahoe
How much Freon and oil to put in a new used compressor
These dont use Freon. Freon is R22
These use R134 -46oz and 13oz of oil. You need to pump down the system though once the oil is added and let it sit with the vacuum pump to remove any moisture. Any moisture left in the system will ruin your expansion valve and compressor quickly. Then add one can of R134 and run the system for a minute to distribute the oil. then add more R134 until the gauges show it at the right pressure for your ambient air .
Sep 02, 2015 | 1998 Dodge Ram 1500 4WD
Oil and refrigerant capacity for 88 chevy s10 pickup
There should have been a sticker on or around the accumulator with the specs.
Oil capacity is the amount drained from the old compressor, plus 3 oz. for the accumulator. Freon charge would be around 36oz or 3 cans.
You would put in 2 cans and then add until the pressure readings are within spec.
Aug 31, 2014 | 1988 Chevrolet S-10
How do you convert r12 to r134 on a Ford Truck?
If there are any leaks in the system, they should be addressed first. The system needs to be recovered of any r-12 and remove the oil and the compressor oil. The accumulator (or receiver/dryer) needs to be replaced. The system needs to have the proper amount of r134 compatable oil added back in. You can measaure what comes out of the compressor and add that amount back in. Then add about one oz. per major component (condenser, evaporator, dryer). Ester oil is good for retro fitting because it is compatable with both oils. There are fittings you can buy (kit?) that screw onto your r-12 ports that allow you to evacuate and recharge it with r134-a. Typically, the new charge amount will be approximately 80 percent of the old charge. IE: if the vehicle held 3.75# of r-12 (x.8) is 3# of r134-a.
Jul 01, 2014 | Vehicle Parts & Accessories
Can i use r134 referigerent in a R12 compressor
yes but you need to rcover r12 then retro fit the hi side and low side then vacume system then when you ad r134 you only ad 80 percent of what the original amount of r12
May 18, 2011 | 1995 Chevrolet K1500
I have this ford e250 2003 model "i think" I just got this 2nd hand. I bring the car to service center to check my air-con for its not cooling that much,. but after the service and change of...
You need R134-a refrigerant with PAG oil for your HVAC system (part number F7AZ-19589-DA) . The capacity is as follows:
With auxiliary climate control:
64 oz R134-a refrigerant
13 oz PAG oil
Without auxiliary climate control:
44 oz R134-a refrigerant
9 oz PAG oil
Mar 15, 2011 | Ford E-250 Cars & Trucks
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
