Question about Apple iMac 24" Desktop
Hi guys, I have an iMac 2.4 GHz Intel Core 2 Duo machine, I had it re-installed with Snow Leopard, but in the process I lost iLife, and the original install disk 1 is nowhere to be found, how can I recover the lost software? Or I have no other choice than to buy a new iLife?
  • 221 Answers
Hello
If you have bought it from the mac app store you should be able to download it again without having to pay ;)
Damien
Posted on Nov 20, 2011
Or you could download it from somewhere. in case apple doesnt like you. macserialjunkie.com codez4mac.com mac-share.com plenty of places for it.
Posted on Nov 30, 2009
  • 2,841 Answers
Contact Apple and explain the situation. They may have a record of your purchase of iLife and send you another CD for a small fee.
Posted on Oct 09, 2009
MA878LL iMac 24" core 2 duo 2.4 do not turn on,
Checking the power supply isn't the easiest thing to do, it involves pulling apart the entire machine.
You can try resetting the SMC, unplugging all power, hold the power button for 5 seconds, replace power, then attempt to turn on.
if it still won't turn on, and assuming you didn't get AppleCare or it is expired (past 3 years) it might be worth taking in to an Authorized Apple Repair Facility and see if they will check it out for free. If it is under warranty, most definitely take it in or call 1-800-APL-CARE
If neither of those are an option, Power Supply http://www.ifixit.com/Apple-Parts/iMac-Intel-24-Inch-2-4-2-8-GHz-or-3-06-EMC-No-2211-GHz-Power-Supply/IF169-002
a tear down from iFixit for the 20" model, it is most likely very similar for your model as well http://www.ifixit.com/Guide/Repair/Installing-iMac-Intel-20-Inch-EMC-2133-and-2210-Power-Supply/1006/1
Hopefully that helps. Good Luck
Feb 23, 2011 | Apple MA878LL iMac with 24" Screen Desktop...
Installing Leopard on my iMac
Yes you will have to clean the disc.
But if you have another mac hook it up to another mac, boot in firewire slave mode, and save thefiles.. (http://docs.info.apple.com/article.html?artnum=58583)
Oct 13, 2008 | Computers & Internet
I have imac. and i want to change his operating
Yes it is very easy to do as you are running a Mac with Intel Processor. You have Mac OSx Leopard with updates 1,2, & 3. To upgrade to Mac OSx Snow Leopard you must buy the upgrade. Go here: http://www.apple.com/macosx/ On the top right click (Buy Now) You will have to pay $29 which is a bargain. Once you get the upgrade on CD simply follow the directions for the simple upgrade. I did the same thing when Snow Leopard came out. It is well worth the $29.
May 29, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Lost my admin password how do I reset it
Restart the MacBook from the original install disk or Snow Leopard install disk, then after selecting the Language, go to the menu and you'll see 'Reset Password', just select the user you want to reset (There will only be one in most cases) type in a new password or leave blank (not recommended) , and restart as normal.
Apr 03, 2010 | Apple aluminum 13-inch MacBook laptop-...
Macbook black will not start beyond the initial 'bong'. Blue screen followed by endless spinning gear. PRAM, SMV reset, no go. Safe mode can't complete. With battery or on power adapter same result....
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
  1. Immediately after the "bong" press and hold down "Command + S".
  2. Wait for blinking cursor and then type fsck -y (exactly like that).
  3. If you receive an "Appears to be OK" then type reboot and hit the return key.
  4. If you receive a "Disk has been modified" then repeat the fsck -y command until you get an "Appears to be OK" then type reboot and hit the return key.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
Feb 27, 2010 | Apple MacBook Pro Notebook
My iMac g4 just got a 1pixal coloured line then 12 hrs later 4 more lines appeared now another 12 or so hours it has grayed out a third of the display. some tech said only way to fix was buy a new one it...
If your iMac is an Intel Core 2 Duo running Leopard, it's certainly not a G4.
From the symptoms described, you have either a bad LCD panel or a bad LVDS cable. Either way, what the tech told you is wrong. They can both be replaced. Whether it is cost-effective or not is for you to decide.
Jan 28, 2010 | Apple iMac G4 Desktop
Bought used iMac and need documentation for Leopard OS.
go to
manuals.info.apple.com/en/Welcome_to_Leopard.pdf
It gives you the basics. The support section on the apple website should help you as well also the help on Leopard is quite good. But if you want to get more information it is probably advisable to visit your local library or buy something like Dummies Guide to Leopard (Not Snow Leopard)
Nov 11, 2009 | Apple Refurbished iMac 20-inch 2.0GHz...
My imac 0s 10.5.7 goes blank and restarts mid work. I thought maybe a mouse problem so took off the wireless and put on the one that came with the imac. That didn't solve the problem.
It sounds like either a hardware problem that has been shown up when you installed Leopard, or your Leopard install hasn't gone smoothly.
IS it a new install?
Jul 22, 2009 | Apple iMac 24-inch 2.8GHz Intel Core 2 Duo...
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Jul 09, 2009 | Apple iMac 17" MA199LLA Desktop
Apple iMac 24" Desktop Logo
120 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
